Right, new owner of a 2016 Leon FR184 ST and so far quite impressed, but as with all things, not yet perfect!
Have already made a mod to enable AndroidAuto (thanks to Tell for pointing me in the right direction), and have OBD11, so I don't mind fiddling.
Three things I do want to address though: 1. Lights - I live in Cornwall and often drive on dark country twisties and find the lights inadequate as they are. 2. Front traction - Maybe it's just the tyres and 280ft/lbs of torque, but 1st-2nd gear traction isn't great! 3. Steering - It feels a little vague at times.
Are these common issues?
The lights seem to be from the mutterings I've read so far. I can't seem to activate Full Beam Assist, but will keep trying. My previous car (Ford) they would come on above 28mph, which worked ok for the slower back roads around here. Is it possible to change the speed setting that the full beams come on at in OBD11 to reduce it from 100kph to 45kph?
Can the height of the dipped beam be raised slightly in OBD11 settings too, as it really isn't great?
I have yet to jack the car up and get the wheels off to give it a good checking over suspension wise, so there could be some loose bushes/tie-rod ends not helping with traction and steering. Also the rear is sitting a little low, so I question whether the springs are stock, might be shifting too much weight rear-ward?
I've heard that a front strut tower brace can help with steering feel, but is there anything else obvious that I have yet to find? Common issues that might need maintenance rather than modification?! Or common solutions a newby to the MQB chassis doesn't yet know about? ?
