Cupra Mode shortcut
henry1
128
24
Morning all,
I have a VZ2 2024 Cupra Leon Design Edition hybrid and one thing is bugging me. If I want to put the car into Cupra mode i have to go into the menu and select Cupra. If you flick the gear lever it alternates between comfort and sport but not Cupra. The VZ2 doesn’t have the steering wheel button. Has anyone found a shortcut to select the Cupra drive profile? Many thanks.
H Rafiq
1,164
537
If you move the gear selector left, does it change the mode or just put the gearbox into sport mode, and hold gears more? I don’t think there is a shortcut unfortunately. You could retrofit a steering wheel with the mode button on it. EYR do this.
henry1
128
24
It doesn’t go left. It’s the short, stubby selector. Thanks for coming back to me though
H Rafiq
1,164
537
Apologies, I’m thinking of the 5f. You could retrofit something like this with the mode button.
BoomerBoom
784
289
You could set one of the infotainment panels to driver profile, or try the voice control - although it will probably argue back.
Reactions: Richiepoos
Seastormer
Cupra Leon VZ2 300/CBF1000
Apr 25, 2014
5,406
913
69
Edinburgh (Scotland)
Morning all,
Afraid not, I do the same as you.
grabania
203
Warsaw, Poland
grabania.pl
FYI replacing the steering wheel is just the beginning. For sure the airbag loom and airbag slip ring needs to be changed, but other parts might also need to be replaced or flashed (especially GW)
Richiepoos
149
50
That's what I've done, have the panel for drive profile - still not as quick as a nice button on the steering wheel!
Mar 12, 2020
Morning all,
I Know this is an old thread, but the quickest way (and to turn off the stop start) is to hold the power button (2secs) on the infotainment and it will go into standby mode and show driving modes and stop start.
Easy peasy.
