Mar 31, 2024
Ive changed the usb port in car to support apple car play and I have also unlocked Full Link via MB2 toolbox. I launch Full link and it only gives me Mirror link option.
What am i doing wrong ?
Incorrect coding
You'll need to enable android auto & apple carplay, and code to suit the new usb port
I have a March 2015 Leon Cupra but it doesn’t have Full Link, AA or CarPlay, and doesn’t have the USB in the central cubby under the infotainment screen. Seat said they can’t activate CarPlay…
Because you have MIB1, you'd have to upgrade to MIB2
Reactions: H Rafiq
Hi mate do u by any chance have the part number (OEM) for the replacement USB port that allows Apple CarPlay ? I have a mk3 Leon 1.6tdi. With a MIB2 head unit been searching online but can only find ones that are marked up as golf MK7 with (OEM) 5G0035222E! Is this compatible or not ?if not which one did you use to replace ur stock part ? Many thanks in advance for your help.
Hello everyone, I am entering this discussion to ask for your help. I recently purchased a Cupra Formentor VZ E-hybrid registered in June 2021. I have tried every way to connect (both wired and wireless) to the car to use Apple Carplay but when I press on Full Link it says the feature is not available. I went to a Cupra Service today and was told that the problem was that the Cupra Connect service had expired; after renewing it, however, the problem persists. Do you have any suggestions?
Your car likely does not have Full Link enabled
