DACA
63
Garstang Lancs
Is there an adjustment to be made to the LED Headlights on Ateca experience 2018 please? Going touring for several weeks. For short trips I have never bothered
Check the user manual as I seem to recall that for short journeys you did not have to do anything.
Reactions: Tell
I'm sure like the Leon the LED lights have a neutral light pattern and therefor can be used on Left or Right side of the road with no adjustment required
Reactions: Tell
Indeed. Those nice EU people made the cars legal for short journeys in either country based on the light design. No need for sticky bits these days on modern cars, well the Ateca.
If you do settle in another country taking the car with you LHD or RHD and vice versa you do need to have completely new headlights fitted.
The Ateca was always like this from launch. There is a section in the manual that tells you.
Quite right the manual does say this if you are there for longer periods then you need to replace the lights. Our other car has a setting to change to alter the LED lights. Normally when I go to the EU is for a couple of weeks but this time is for longer hence the question. I simply wondered id there was an OBD11 setting. Not to worry I am happy with the SEAT manual's answer. Thanks guys
