One touch window open/close
MA1601
59
17
The driver side master window switches for passenger and driver windows stopped working for a few days after they got wet recently. They now work but the one touch open and close has gone. I've tried doing the reset trick but doesn't seem to help. I'm now thinking a new switch panel is needed?
serdar_18fr
563
I would try running some live data checks on the switch before replacing it (using a diagnostics tool like OBD11 or similar), to see if it is really broken or it is something that could be rectified by applying basic setting procedure.
Sent from my 23113RKC6G using Tapatalk
Mo_86
306
115
UK
Have you tried holding the button all the way up without click then when it gets to the top while holding it, then do the click.
MA1601
59
17
Thanks didnt think of that - will have a look.
Reactions: serdar_18fr
MA1601
59
17
Yes have tried that, think the switch might have got some permanent damage from the water unfortunately.
SuperV8
1,889
952
Which re-set procedure did you follow?
I found the common way which you find on google & youtube didn't work for me - so followed the one in the manual which worked.
Reactions: Jason2023 and Mo_86
MA1601
59
17
I have tried the reset detailed in the manual above, still no luck although day by day it is getting better and starting to work more. Will try to get hold of contact cleaner. Thanks for the suggestions.
Mo_86
306
115
UK
It isn't a sticky window is it, if so try some 3in1?
nanobis
23
Thanks for this, I should have looked in manual myself, as I was just wondering if my car had the one touch open/close as it wasn't working. I'll give this a try and reset it.
