Facelift door panel removal
CRNeo
402
7
Liverpool
Hi, I need to remove the door panel on my mk2 facelift as someone has smashed my mirror off. I started removing the panel thinking it would be like any other car but seems maybe on the facelift it's tied into the door lock/windows?
I've pulled out some of the clips now at the bottom not realising the whole thing lifts up (but there's bits still attached not letting me)
I'm struggling to find instructions or vids on removal... anyone done this and can help at all or point me in the right direction?
TIA
gaz82
48
15
Just let it hang there while u take the mirror off otherwise you have to take the window mech motor off the door card i had my card off for the first the other week i let it hang ther while i did what i needed to do take the speaker out it helps with putting it back together as u can get ur hand in to hold the rails in place for tgem 2 bolts at the bottom of the card
gaz82
48
15
Just let it hang there while u take the mirror off otherwise you have to take the window mech motor off the door card i had my card off for the first the ither i ket it hang ther while i dud what i needed to do take the speaker out it helps with putting it back together as u can get ur hand in to hold the rails in place for tgem 2 bolts at the bottom of the card
Plus i think u can access the mirror by just pullin the door card insert out then gettin ur hand up ther sure its possible
