2016 Leon - weird issue with driver door locking itself
mjgreen81
15
Hi all,
I've got a 2016 Leon 1.4 FR which has developed a weird issue with the driver's door lock over the last month or so.
When I first unlock the car in the morning, I typically open the rear passenger side door first so I can get my daughter strapped in. I then open the driver's door and find it has locked itself. When I unlock the car using the fob, I hear the driver door automatically locking immediately and I can't get in. I then have to open the door from the inside by entering via one of the other doors (all of which are unlocked).
I can't seem to replicate it, it only happens first thing in the morning (and doesn't happen every day, it maybe happens about once a week) and only seems to happen when I open the rear door first (might be coincidence).
Any ideas what is happening here? I guess my main concern is something is slowly failing and will completely fail soon.
I've looked through the locking settings and can't see anything that might be causing this.
Thank you in advance
gaz82
48
15
Locks are notorious for failing on seats especially in winter colder times my rear passenger door does it every now an then only wen its cold all the other 3 locks have been replaced wen i bought the car was given the lock the ownernever got round to doin that one but gave me the lock
gaz82
48
15
The wires can get faulty in the rubber boot were it goes from inside the car into the door as ther allways being bent
mjgreen81
15
Any idea why it would behave like this only when I open the rear passenger door first?
gaz82
48
15
Maybe it thinks the car hasn't be entered so it locks the doors again so u press the button on the phob then dont enter the car after a certain period it will auto lock or ur lock is faulty and sticking now an then so if u unlock open the drivers first everything is fine
monikagreyy
14
Hi all,
games online casino are full of creativity and charm, often offering more innovation than big-budget titles.
It sounds like your driver’s door lock actuator may be starting to fail, especially since the issue is intermittent and only affects one door. Moisture or temperature changes in the morning could be triggering a weak actuator or a faulty microswitch inside the lock mechanism—worth checking before it becomes a permanent fault.
mjgreen81
15
Hi, thank you.
I can confirm that it was the drivers lock. It completely failed a week or so after posting this thread.
I took a punt on a second hand replacement lock from eBay which only cost £12. It took a couple of hours to fit but the process simple enough with some help from a YouTube video but it's been working perfectly for several weeks after fitting.
