Apr 2, 2025
Hello Guys, Hope you can help me with a rattle that drives me crazy.
I’ve been experiencing a loud rattling noise from the rear / right door, both very annoying, it always comes up, specially when driving on uneven roads, at least that where I notice them from.
See video I posted on reddit, hopefully the rattling is noticeable to you, wind hides it on video, I record the front side but I'm sure it comes from the back.
I’ve seen formentors experiencing similar noises, either on threads here on Reddit and forums online.
I would really appreciate any advice, I’ve been to my nearest Cupra Garage, unfortunately the tape they put around the doors was no solution, no other Cupra garage is near me unfortunately.
My best guess is something is loose under the door panels, I would appreciate any orientation or if someone has already solved the issue if experienced it.
Hope you guys have more info on what the origin of the rattle is.
Thanks for the advice.
Are you sure the source of the rattling noise is actually from the rear doors? Locating the source of unwanted interior noises can be notoriously difficult, especially if you’re trying to do it yourself while driving. A common source of unwanted cabin noise in many VAG cars that’s reported on many forums is the rear seat backrest latching mechanism. Because of its proximity to the rear doors, if that’s the source of the rattling noise in your car it’s possible it sounds as if it’s coming from the doors.
I had this issue with a mk6 VW Golf I owned some years ago and an effective DIY fix is to wrap some anti-squeak / anti-rattle tape (or even electrical insulating tape) around the metal loop that the rear seat backrest latches onto when in the upright position; the tape removes any free play between the two parts of the latching mechanism so stops unwanted rattling noises - that’s assuming the latching mechanism is the source of your problem. The loop and latch are at positions ‘A’ and ‘B’ in the picture below (it’s a mk3 Leon ST in the picture, but the latching mechanism should be the same in other Seat / Cupra - and other VAG cars). If the tape wears away over time through repeated raising and lowering of the rear seat backrest, then it’s quick, cheap and easy to replace.
Please update this discussion topic for the benefit of other forum members if / when you try this fix.
Reactions: gale7
Thanks for the advice, took the car out with backseats down, so no contact in the rear seats latching mechanism, the rattle was still there, so my guess its not that.
My perception is the pillar that holds the seatbelt, perhaps the rattle is from elsewhere, any other suggestion would be greatly appreciated.
Reactions: dang81
My tip for finding rattles is to thump your fist (lightly) repeatedly against the panel you think it's coming from, to make it all vibrate and resonate. If there's something loose in there it will sound like it does while you are driving.
While you are driving it's impossible to find them, also make sure you've emptied all your c**p out of the car first - spending hours only to find it was your deicer tin is annoying.
Also, take a passenger with you - as @BoomerBoom has said, it’s impossible to find unwanted cabin noises while you’re driving. The passenger can also be an extra pair of ears and listen for the source of the unwanted rattling noise to try and pinpoint where it’s coming from. They can also sit in different seats in the car - and travel in the boot / trunk if necessary - and apply pressure to the interior trim panels while you’re driving.
Hopefully, with with a passenger in the car, along with the method suggested by @BoomerBoom, you’ll be able to track down where the rattling noise is coming from and fix it ?.
Good luck.
I was trying to track down a knocking sound coming from somewhere near the pillar — I could clearly hear it by ear. The authorized service went through the whole pillar, added damping wherever possible, but the noise didn’t stop. In the end, it turned out to be a poorly adjusted door latch that was slightly knocking on bumps. They adjusted it, and the sound disappeared.
I'm having the same issue. Thinking it maybe from the door pillar. I had the door card off and it's still there.
Hello!
I'm experiencing a similar rattle on the rear right-hand side. I've tried to locate it without success — removed the panels to check for anything loose and even drove with the rear seats down, but the rattle is still there.
Just wanted to check if you were able to figure yours out — I’d really appreciate any insights!
Hey!
Hiya,
it actually turned out to be a mis-aligned front driver door catch.
When it goes for service, I’ll get them to fix it. Currently has a piece of duct tape wrapped around it to stop for now.
Hope this helps :)
Hiya,
Hope this helps :)
So the same problem as me, few posts ahead.. :)
I had a rattle from the rear spoiler. Slam the boot lid down - can you hear it then?
I had it refitted/replaced under warranty. It still rattles a bit, but not enough to be noticed over all of the others!
You saved me from hours and hours of trying to figure out what is that annoying sound. Thanks.
