Gpf advice
NoSmokeNoPoke
Hello everyone. I have a 2020 Cupra 290. I want to drop down the gpf filter and cut it at the top, remove the internals and weld it back up. This is so when it’s inspected for MOT it will not fail. ( I’ve been told aslong as it’s visually there it won’t fail) is this correct?
The car is just so quiet at the moment and I don’t think a res delete will do anything noticeable with the GPF still intact .
Is what I’m going to do ok? Will I get warning lights, limp mode or any running issues until I can get a remap done?
I appreciate any advice as I’ve only ever worked on older cars .
Thanks. Jim .
NoSmokeNoPoke
Hey Piggasinaris,
Thanks for the response mate. I was under the impression that they only tested the GPF if they actually saw it so it’s nice to have that cleared up.
Are you clued up to know if I will get any lights on the dash or any issues with how the car drives ? It will get mapped but in the meantime I’m good?
I’ve always de-cat’d my cars(won’t be on this one) so I’m not worried about the law , it’s more I have to drive a fair few miles to get to the MOT station and he is a bit dodgy. It would be nice to just drive to any normal MOT station that nearby and get it done.
If I try a new place and they fail it, can I just go back to my other guy and he will pass it ?
Jim
Reactions: Shortly
DEAN0
Old Git
Feb 1, 2006
5,440
Preston - UK
The last few MOT's I have gone through - every car i have watched ( including mine ) has had a tailpipe emissions test done.
They enter the car reg in the machine and it loads the accepted emissions data.
The regs are only going to get tougher ( upcoming changes are the car to be photographed during the MOT )
ALSO - any fail or advisory on an MOT will be on the system so whoever does the retest will know what the issue is/was.
Mo_86
319
119
UK
A friend of mine with a gti had his removed, once on the floor the amount of sandy residue that came out was worrying.
Unlike a dpf it seems like there's a concrete block in the filter lol.
Anyway you will need to code out regens and tell the car there isn't a gpf anymore as you will get a fault code after a few miles.
Btw the sound is so much better I'm thinking of getting it done on my 190 tsi.
Thanks. Jim .
The car will likely go into limp mode without a suitable GPF delete carried out via tuning
queen
~Nassia~
Nov 29, 2010
727
88
Athens, Greece
Thanks. Jim .
You will get a check engine light immediately and until you code it out. The car will drive fine if you drive it normally unless you floor it, then it'll go into limp mode. So you'll be driving with an EML until you get to your tuner. The GPF is very restrictive so the first thing you'll notice is how better your car will sound, even during normal driving.
That's what happened in my case as I have the same car. I had the GPF removed and I drove with an EML for about 30 minutes until I reached my tuner.
NoSmokeNoPoke
Thanks for the reply. I can’t get my remap done until 3 days after the GPF delete so I’m hoping if I drive steady I can get to work and back until it’s done.
Is your system standard other than the GPF delete? Would love a video of what it sounds like if that’s possible .
Is it too loud with GPF and a res delete?
Thanks. Jim
queen
~Nassia~
Nov 29, 2010
727
88
Athens, Greece
Thanks. Jim
I think you'll be fine for a few days.
I have a big turbo now so a lot aren't stock.
I think it will be very loud, I believe Seat went with a not so quiet back box as with the GPF it was already too quiet.
When I went big turbo I already had a GPF-back 76mm milltek exhaust (non res), and just changed the downpipe to an 80mm with a high flowing sports HJS cat, I could wake up the whole neighborhood! During cold start it was causing a small earthquake. Pulling away from a stop light it sounded like a tractor or like a hot rod at santa pod staging for a race. :ROFLMAO:
Now I have a resonator fitted, the biggest I could get and it's still loud but I like it that much.
Good luck with everything!
