Indicator issue
Apr 6, 2025
8
Hi All
I have a issue with indicator not working, with ignition on or car started indicators dont work , just the wing mirror ones , just get a dash light msg and fast flash on the cluster, hazard work only when car is off.
Ive checked all the fuses, seem fine. Ive changed the stalks, this worked for a week then back to square one!
Any suggestion what check next? this 2018 FR . Is there a relay and where is it?
Thanks all for your suggestion
Apr 6, 2025
8
Are all the bulbs okay? What message appears in the cluster? As a last resort, read with obd eleven.
Apr 6, 2025
8
all the bulbs are fine, they working .
today i tried again and indicators worked with ignition on, but it was faint/weak till it all stopped working again and fault appeared on the dashboard
Fault codes comfort module say Open circuit fault for them lights. no other errors.
wiring fault, ground?
José Silva
261
51
Portugal
I think I will have to go to Seat. It could be some electrical or electronic part of the car that broke down. (it can be a relay)
Apr 6, 2025
8
the indicators decided to work today, but after 10 mins they stopped.
After few diagnosis was told bcm / central control module is faulty
Can this be swopped and coded/ adapted via vcds ? what are the chances of CP activating by fitting used bcm module?
