Is my car a lemon or are 92 faults normal from OBDevelen?
jeeeefff
67
8
This is a scan immediately after wiping all error codes, again keeping only parts that show error cords, do let me know if its easier to analysis the problem with the unedited/shortened text:
11th April 4:57pm after wipe VSSZZZKLZNR004459 Seat Leon
OBDeleven data log
Date: 2025-04-11 17:57
VIN: VSSZZZKLZNR004459
Car: Seat Leon
Year: 2022
Body type: Hatchback
Engine: DLAA
Mileage: 23654 KM
09 Central Electrics
System description: BCM37w_M1
Software number: 5WA937086M
Software version: 0174
Hardware number: 5WA937086M
Hardware version: 026
Serial number: BXJ53F23062194061467
ODX name: EV_BCM37w
ODX version: 007001
Trouble codes:
C107E54 - Headlight No basic setting
static
Date: 2025-04-11 17:56:25
Mileage: 23654 km
Priority: 4
Malfunction frequency counter: 1
Unlearning counter: 40
Terminal 15 status: On
Terminal 50 status: Off
Engine running: Off
Status of brake lamp switch, discrete: Off
Brake lamp switch via CAN, status: Off
Voltage: 11.9 V
Outside air temperature: 22.0 °C
Light switch position: Automatic
B201B00 - Program monitoring
static
Mileage: 23654 km
Priority: 6
Engine running: Off
Voltage: 12.0 V
I will make another log after my next drive with the car to see if the same 7 seven active errors shows.
cairus
1,572
552
You have s Problem with your Gateway, check the Plug.
Then Drive To the Service Station and make s light Basic Setting and check
  • Love
Reactions: jeeeefff
jeeeefff
67
8
Thanks for pointing me in the right direction @cairus.
I'll find out how to get to the gateway plug and see if I can check and re-seat it. Likely be tomorrow in better light. Do I need to disconnect the car battery prior to doing this? I've not found any info specific to the Leon MK4, the MK3 and users did do this if I read correctly.
I will see if I can at least address the: C107E54 - Headlight No basic setting.
pasting the following for my reference though I dont recall seeing any of this in the Non VAG version of the app:
Make sure the car is on level ground and that the suspension is settled
Procedure 1
From the main OBD11 screen, select the hex55 module
Select Basic Settings
Select Basic headlamp setting and start the procedureThis is where you would adjust the headlights using their manual adjusting screws as referenced against a suitable aiming target - but in the case of "lost basic setting" error just go to the next step
Wait a period of time (suggest 3 seconds)- then stop the procedure
Procedure 2 (still in Basic settings)
Select Acknowledge basic setting and start the procedureThe reference settings from Procedure 1 above should now be "recorded" in the moduleWait a period of time (suggest 3 seconds)- then stop the procedureBack-out of the module, clear any error codes and exit OBD11 software (don't forget to disconnect the OBD11 dongle)
and I'm assuming the top is for left and right, the bottom one is for up and down:
jeeeefff
67
8
Please do not adjust your lights yourself.
Thanks for the warning. I wont. They do seem to aim very low and have never been able to find how to adjust via the touch screen panel, like the physical 1 2 3 roll dial you have on older cars.
jeeeefff
67
8
Yes, I agree. Also, your software is ancient; my hardware is older 752. I have Software version 7310
thanks for the heads up on this buddy. I'm getting the car looked at but a technition today who has a ODIS device so hopefully this will get updated, I've also printed those reports out, highlighting the ones that have reoccured over the past 3 weeks and removing the parts that don't have any errors. Thanks for the help and insight on this guys.
