Lozzy15
Dashcam wiring guide for MK3 Leon
Walone
1,720
508
Near Heathrow
Well, after 8 months of having the cable for my rear cam running along the centre tunnel and over the rear seat, I finally got round to running the cable along the right hand side of the headlining to the rear camera!! :D
Reactions: Lozzy15
Feb 3, 2025
Great write up. Cane here after a search.
I have a strange issue though.
The 12 volt lighter socket from the centre console was live, I've used it with a tyre inflator . I performed this installation using a piggyback fuse and I put the 20 amp fuse in the top of the piggyback and put the piggyback it in F40. The dash cam works perfectly but the centre cigarette lighter socket stop working. it used to work.
What on earth is going on there
Edit: fuse not blown!
kevster184
686
29
I'd test the power on the fuses or if they don't have the little test points remove them and check the female connectors in the piggy back housing.
Feb 3, 2025
thanks for that but will it not be the case that if the fuse was in error or the piggyback sockets were in error ... then the dash cam wouldn't power up anyway?
DutchCupra75
9
9
Netherlands
Guide now located in the new resources section of the site
Hi, hope you'te still in this forum.
I wonder how did you connect the Blackvue to te cloud?
I have an 2023 cupra Leon, blackvue cloud DR770 but can not get it connected. I thought would be pissible over the car cupra connect wifi or e-sim system. So i can watch the dashcam luve from anywere.
Lozzy15
Mods mods mods
580
395
Ilkeston, Derbyshire
Hi,
Sorry but this isn't something I can really help with as I never utilised that feature of the dashcam. I think it can auto connect when it's in range of a wifi network, such as when parked on a drive with good wifi signal. It would have to remain powered while it did this though, possibly via parking mode?
Sorry I can't be of much help! Best of luck getting it sorted.
Regards,
Lozzy.
DutchCupra75
9
9
Netherlands
Hi,
Regards,
Lozzy.
Yes, when connect to the wifi of your phone. But new cars have WiFi in their system and i know you can connect to to WiFi car system so it is 24/7 connected and now mather where on the world you are you can live see the video
