New Terramar keys
May 14, 2025
Hi all, just had our new Terramar lease car delivered and the two keys are 'tied' together by a metal ring attached to a white plastic tab thing as well as a VIN tag. See picture. Is the white tag anything? How do I separate the keys from the ring/white tab/each other?
Apologies for the daft question - newbie alert!!:ROFLMAO:
Cheers in advance
May 14, 2025
The white tag will be from the dealership to keep the keys together on their key board if the black tag got damaged. A pair of side cutters will get it off
Cheers bud, thought it was something like that but with all this tech these days thought it best to check
James_R
5,685
109
37
Manchester
It'll need cutting off if it's been locked in place, that one you have looks like it has.
Tell
Throw my two pennies worth in. Would that white piece be a security scanning tag which set of an alarm if one tried to nick it / contains the ID of the keys. Suspect there is a chip in it which act as the ID for internal purposes. Can be cut off. Might even be read by the Vag mothership when setting up the keys. Set up. Can be removed.. ..
James_R
5,685
109
37
Manchester
Its just a plastic tag used for marking up keys. Nothing electrical inside.
Reactions: Tell
