Chariot
41
13
Hi folks
was just browsing as the OEM standard sound setup is no longer doing it for me
what's your opinion on these: https://celsusice.co.uk/universal-8-200mm-2-way-component-speaker-set
Some questions I can't find an answer to:
Will these be a direct swap for the OEM speakers? (do they need adapters maybe?)
What about mounting depth. Just how deep can the speaker be, before it interferes with anything in the front doors?
thanks
Those are daft money.
You would be better off getting Focal ISU200 speakers + adaptor rings + connector adaptors
Will be the right side of £250
Reactions: Chariot
Hey Dean0
I agree with you that the price is ridiculous, part of me thinks YOLO though, since they are going to get punched almost every day for 5 years. I picked them, because they are shallow mounting. (61mm). I think the ISU200 are 66mm, but please correct me if wrong
Nobody seems to be able to indicate what depth the speakers can be. This is what is holding me back on other options
ISU200's fit perfectly
Reactions: Chariot
uh yeah....lush (don't know what i was thinking when I saw the Morels LOL)
did you need to buy rings, plugs or anything other than the ISU200 kit?
You need mounting rings.
You need connector adaptors unless you want to cut the connectors off the loom and solder the wires.
Say...
you don't happen to have info on the rings (like a link or part numbers or details). (I had a look at the current speakers and it has hex screw (as opposed to rivets)
and no, deffo need some proper connectors, as I don't want to damage the existing OEM setup
thanks mate, I appreciate it!
These are the mounting rings I used
Reactions: Chariot
