Where are you located?
How much?
If you do the necessary update to allow for Full Link activation, you'll have to code the software management into the control unit. If you need to code yourself, it'll cost you money anyways, so why not grant the local specialists the business? I've had to get myself the OBDeleven tool and the pro subscription because nobody in my direct vicinity even knows what they're doing and the dealer charges over €380 euros for an update.why don't you do it yourself?
£99.99, including a free software upda
Can it be done remotely or do you have to have the car in person?£99.99, including a free software update
Could you provide instructions on how to do this with OBDeleven please? Dealer here in Ireland is asking for €450, and I already have an OBDeleven.If you do the necessary update to allow for Full Link activation, you'll have to code the software management into the control unit. If you need to code yourself, it'll cost you money anyways, so why not grant the local specialists the business? I've had to get myself the OBDeleven tool and the pro subscription because nobody in my direct vicinity even knows what they're doing and the dealer charges over €380 euros for an update.
For software versions including full link unlock, check out https://mib-helper.com/.
So this method won't work without that firmware?The reference to mib helper is correct. However, it also refers to mib solution, and since the last time it was offline, there is no longer any firmware there that is required here.
I am literally on MIB Solution right now.The reference to mib helper is correct. However, it also refers to mib solution, and since the last time it was offline, there is no longer any firmware there that is required here.
