Any decent alternatives to carista/obd eleven/vcds?
kazzz25
31
For Car Scanner best obd module is Vgate iCar Pro 2S. Very fast and stable.
Applications are solved differently than in Carista or obd11. You select the module you are interested in from the list (engine, transmission, lights, etc), open the options and get a list of what can be activated.
In the evening I can take screenshots of the app if you want.
If you could please that'd be awesome!
Karollo
44
35
Poland
It seems to me that there is no such possibility. But I could be wrong. I have never seen such a setup.
kazzz25
31
The coding is the same no matter what application you do it with.
I've installed the app and it's asking for the initial setup connection profile. Which one should I pick? Typing Leon it only gives the diesel engine and typing 1.4 I'm not sure if that is the correct one. Any way to double check? Thanks
Karollo
44
35
Poland
Seat/Obd-II/E-obd (first profile)
Karollo
44
35
Poland
For coding applications/settings this profile I wrote about above is sufficient. If you need to do something more then you need to choose a profile compatible with your car.
Reactions: kazzz25
kazzz25
31
Thanks!
And probably last question. Any tips on using the app? Should I do a scan or anything before making customisations? Is there a way to revert long coding changes? I'm guessing for the others like enable/disable I'd just switch it back to the other option.
Thanks!
Karollo
44
35
Poland
Perform a backup of the entire car before the first changes. The application will display information about it. In case some coding does not work as needed, the backup will restore the car to its original state.
Reactions: kazzz25
ARH
24
13
I can vouch for the restore backup features of car scanner it is easy to undo any mod you make, have not tried a full restore but have restored single changes a few times.
Reactions: kazzz25
kazzz25
31
Thanks! I can't find the needle sweep, parking display to come on with the parking sensors in the normal options I've been through them all. I selected seat obd profile then mqb.
