Nov 4, 2025
Hi All
I became the Cupra owner for the first time a month ago. Loving the car but have recently had a cog light come on that is worrisome. I’m sure it will be mentioned in the forum so will read up on it. Looking forward to getting to know all things Cupra, cheers Tony
Reactions: Syphon
Hi All
Welcome to SCN Tony, hope you get the problem sorted and keep enjoying the motor.
Hi All
I became the Cupra owner for the first time a month ago. Loving the car but have recently had a cog light come on that is worrisome. I’m sure it will be mentioned in the forum so will read up on it. Looking forward to getting to know all things Cupra, cheers Tony, Doodle Baseball
Добро пожаловать и поздравляю с покупкой!
‘Cog light’ обычно указывает на проблему с трансмиссией или систему управления двигателем. Лучше всего считать ошибки сканером — это быстро уточнит причину. Иногда помогает простая перепрошивка или датчик, но если лампа горит постоянно, стоит заехать к дилеру, чтобы не усугубить проблему.
Welcome and congratulations on your purchase!
'Cog light' usually indicates a problem with the transmission or engine management system. It is best to consider errors with a scanner - this will quickly clarify the cause. Sometimes a simple flashing or sensor helps, but if the lamp is lit constantly, it is worth stopping by the dealer so as not to aggravate the problem.
