Cupra306Form
135
90
Anyone suffering from the repeated "Emergency" or "Travel" assist errors that are steering wheel related that Cupra / VW / Audi / Seat and Skoda suffer from whose dealer is unable to help I visited East Yorkshire Retrofits who found the fault, showed me what was causing it and fixed it in about 20 minutes. It's not a cheap fix, you have to buy a new part, but it was done quickly and after a long drive home and 2 more trips tonight so far so good. There is also an unintended positive consequence of the fix in the way the car can be driven that is probably best not highlighted on a public forum.
I had noticed sometimes the fault went away, but I hadn't realised it was after using the heated steering wheel that helped. As a temporary fix anyone suffering - and that is the right word - from this fault stick the wheel heat at level 3 for 10-15 minutes to get it really hot and it should stop the faults for a while. (Tip from East Yorkshire Retrofits)
Cupra Liverpool have had 3 goes at fixing this and had basically given up saying awaiting a fix from Cupra.
I forgot to say thanks to @East Yorkshire Retrofits by putting the @ there :)
Wonder where the heating comes into it ?. Duff connections ? Or dampsness ?. Altea use to suffer from cruise control issues like it didn't work. That was dirty contacts in the switch stalk but I wasnt brave enough to take it apart and clean it. Instructions on the board at the time. Really you'd expect these issues to be picked up and sorted out before the car is built as part of testing the design.
Reactions: Cupra306Form
My thoughts are that if heat fixes it it's probably moisture, sweat from the hands getting through the pores in steering wheel leather affecting the measurements taken about hand contacts? Although I suppose any leather cleaner used on the wheel might also be a factor, I have cleaned mine occasionally. I had my heated wheel on the day before my trip to get it fixed and never got a single beep, on the day I travelled over 60 miles before I got one, it had been either sounding or showing unavailable pretty much constantly before that, often from start up before I touched the wheel.
A quick look at VW forums shows some golf owners have had 3 new steering wheels under warrantee - what a joke.
Reactions: SRGTD and Tell
Leon 4 people like to change their steering wheels and some on recent Ateca's, why. I haven't got down to the bottom of that one. Probably moisture and all those touch sensitive controls that people dont like playing havoc with the electronics. :unsure:
Changing the steering wheel was VW’s solution to this issue but a new steering wheel didn’t always fix the issue or if it did, the fix was sometimes only temporary; as @Cupra306Form has said, some owners had multiple replacement steering wheels; must have cost VW a small fortune in warranty claims.
Interesting that VW reverted back to conventional physical buttons on steering wheels for most models, although strangely, touch sensitive controls have been retained for the mk8.5 Golf R. I can’t recall reading of owners of any current / latest VW’s with conventional steering wheel buttons having the travel assist issues that were experienced in cars with the haptic touch sensitive controls.
Reactions: Tell
Well with a car bouncing around trying to get a touch rather than a click is going to be a bit haphazard whilst driving. You'd think they would boil a kettle under them to test them for humidity ;) . Going through multiple screen isnt something you want to do driving.
Brother use to work at the Vauxhall proving ground where they would drive and drive cars, crash and crash them till they got it right. Strip down the competitors cars to see how they were engineered. Been round the bowl at 100mph... a family perk :). Brother use to bounce the cars over MKs old humpback bridges with test equipment on the suspension. How does this car bounce.
Just in time is when it all went wrong for Vag, putting aside diesel-gate. Mib3 the grand plan to software update them on the road. Cut down testing to save money.
Managers not understanding tech but on diesel-gate, that America is hot on car emissions for 50+ years. Obviously American emissions people would say, how can they do this with this arrangement... they found out. They tried to stop Concorde flying into America on emissions. That smokey old engine. Probably VAG staff are too young to know. ~50 years later they rumbled Vag trying to do the same. Managers not understanding software development was the new one.
Anyhow we have that new control system coming along for EVs... we will see whether it's money well spent.
Reactions: SRGTD
The issue on VW vehicles is caused by a defective touch sensor that's fitted within the steering wheel.
It relies on on the likes of heat and pressure from your hands to determine if you have hold of the wheel or not. If it can't detect your hands then the car will turn off the assist systems.
Turning the heated function on will override the system all allow you to use the assist functions again.
Steering wheels on VW and steering wheel control modules on Seat/Cupra have cured the issue on vehicles I've dealt with. They currently tend to last about 18 months before the issues start to arise again.
In a lot of people's opinion, the haptic touch buttons are a massive own-goal by VWG. The novelty wears off almost immediately.
One for James I dont use travel assist on my 2017 Ateca model it might have stopped working already. No haptic buttons on that but it does have a feature to determine whether you got your hands on the wheel. But since I rejected lane assist and traffic assist two months or so since I had it, I'm blissfully unaware. These days they force you to use lane assist so if that sensor failed you'd get a light show I guess.
Anyone suffering from the repeated "Emergency" or "Travel" assist errors that are steering wheel related that Cupra / VW / Audi / Seat and Skoda suffer from whose dealer is unable to help I visited East Yorkshire Retrofits who found the fault, showed me what was causing it and fixed it in about 20 minutes. It's not a cheap fix, you have to buy a new part, but it was done quickly and after a long drive home and 2 more trips tonight so far so good. There is also an unintended positive consequence of the fix in the way the car can be driven that is probably best not highlighted on a public forum. I had noticed sometimes the fault went away, but I hadn't realised it was after using the heated steering wheel that helped. As a temporary fix anyone suffering - and that is the right word - from this fault stick the wheel heat at level 3 for 10-15 minutes to get it really hot and it should stop the faults for a while. (Tip from East Yorkshire Retrofits) Cupra Liverpool have had 3 goes at fixing this and had basically given up saying awaiting a fix from Cupra. I forgot to say thanks to @East Yorkshire Retrofits by putting the @ there :)
Well, I have the same problem on my Leon yet I’m in France and can’t ask for East Yorkshire help.
Would you be so kind as to explain what the fix was so I can try finding a garage around to replicate the solution ?
Thanks in advance
Thanks in advance
I guess a new steering wheel and disconnecting the function that stops the car thinking you have fallen asleep. Only my guess. I know a lot of Leon 4 drivers had a big interest in changing their steering wheel. I guess the secret sauce is leaving something not connected or coded out so when the dampness issue reoccurs its not picked up. Only my guess.
I guess a new steering wheel and disconnecting the function that stops the car thinking you have fallen asleep. Only my guess. I know a lot of Leon 4 drivers had a big interest in changing their steering wheel. I guess the secret sauce is leaving something not connected or coded out so when the dampness issue reoccurs it’s not picked up. Only my guess.
As you said, we’ve been some L4 owners to switch our wheel for a capacitive one. So changing the steering wheel, I’m able to do that myself.
Though, I was hoping for a different solution that did not involve that but more something like you mentioned, cancelling hands on wheel or coding something else out
Its not the telematics box then ?. That's the one that originated the faults in quite a few instances rather than the wheel and the cars systems. Those two you can't do yourself. Try a different dealer if yours can't fix it.
The factory solution was a initially a new capacitive steering wheel control module, then this changed to a new wheel and module.
Reactions: Tell
I’ve had the problem today and I don’t think it’s linked to the wheel or a module in my case.
Each time it fails is when the car enter proximity mode.
And today when parking on the drive place to get my groceries, it didn’t miss, as soon as proximity mode and the bip began, emergency and travel assist failed.
Also this weekend, had the error, passed through a narrow road with lots of bushes and every side, the car was beeping like crazy but hey magic, the error disappeared.
Well, I’ve got to bring my car to the dealer at the end of the year, I’ll see then.
May even try to make videos of the problem to show them
The last 2 weeks my Formentor VZ3 has been intermittently showing the following 4 messages;
- AAC sensor impaired
- Front Assist is unavailable. Sensor impaired
- Travel Assist is currently unavailable. Sensor impaired
- Error: Emergency Assist
Time to pop to my local Cupra Dealership and begin the warranty claim process.
As my car is just 15 months old, Can I assume that this problem has not been fixed and it's an exercise of throwing new parts at a problem that will ultimately reappear when the car is out of warranty?
Perhaps the touch sensitive sensor in the wheel can be coded out?
- Front Assist is unavailable. Sensor impiared
- Travel Assist is currently unavailable. Sensor impiared
Until you know what codes are stored, a defective steering wheel is just an assumption at this point.
2024 onwards vehicles don't seem to suffer with the steering wheel issues.
