Anyone suffering from the repeated "Emergency" or "Travel" assist errors that are steering wheel related that Cupra / VW / Audi / Seat and Skoda suffer from whose dealer is unable to help I visited East Yorkshire Retrofits who found the fault, showed me what was causing it and fixed it in about 20 minutes. It's not a cheap fix, you have to buy a new part, but it was done quickly and after a long drive home and 2 more trips tonight so far so good. There is also an unintended positive consequence of the fix in the way the car can be driven that is probably best not highlighted on a public forum.
I had noticed sometimes the fault went away, but I hadn't realised it was after using the heated steering wheel that helped. As a temporary fix anyone suffering - and that is the right word - from this fault stick the wheel heat at level 3 for 10-15 minutes to get it really hot and it should stop the faults for a while. (Tip from East Yorkshire Retrofits)
Cupra Liverpool have had 3 goes at fixing this and had basically given up saying awaiting a fix from Cupra.
I forgot to say thanks to @East Yorkshire Retrofits by putting the @ there
