Ploppy
21
16
Hi all
I’m after genuine part numbers pads discs front and rear for my Seat Leon Cupra 300 ST manual box 2018 uk spec Please
Ploppy
Hi all
Ploppy
If you don't mind sending me your VIN via a private message, I can look up exact part numbers for your car.
There are a lot of members around here that I helped this way, as you can see in my previous posts.
Regards,
Serdar
Regards,
Serdar
Thank you
Will do
Reactions: serdar_18fr
Thank you
Will do
Here are the part numbers of brake discs and pads for your car:
5Q0615301G
Brake disc, vented, front, 340x30
x2
5Q0698151AJ
Set of brake pads, with wear indicator, front
x1
5Q0615601E
Brake disc, vented, rear, 310x22
x2
3Q0698451N
Set of brake pads, rear
x1
Front brake system PR code: 1LJ
Rear brake system PR code: 1KJ
Hope this helps,
Serdar
Reactions: Ploppy
