May 29, 2025
I recently just bought a rain/light sensor from Ebay (#8U0955559A#) and fitted it to my 2017 Seat leon FR technology 5F with climate control, after coding the sensor using obdeleven adaptations the light sensor appears to be working as I now have CH/LH in auto switch position but the rain sensor live data is still saying that it is not installed/not coded
Can anyone help as this has me bamboozled and annoyed as the auto wipers is why I did this in the first place
They come with a climate control system as default but the rain and light sensors only came with the comfort pack addon which I didn't know till after I bought mine as I presumed what I now know as the humidity sensor behind the rear mirror was the rain sensor
Reactions: Tander
What coding did you use for this, just in case there is something off with it and what subsystem are you updating.
What coding did you use for this, just in case there is something off with it.
On my 2017 leon FR the 09 central electronic long coding doesnt work, I enabled the sensor in the adaptation "Assistance light functions" under "Regen_Lichtsensor->LIN_Regen_Licht_Sensor" and then in the multifunction module long coding "byte 7 ticked bit 1" i think for the rain/light sensor. Only thing that hasn't worked unless I am doing it wrong is the window closing on rain detection but no issue for me with the climate system
I have the same car as the OP and have recently bought the auto light switch (5G0941431BD) and sensor (5Q0955547C).
Please can someone confirm the correct coding required on obdeleven? I tried some coding from information found on this forum and elsewhere online but I am not sure how I can verify if the car is detecting the new sensor. I did see it mentioned somewhere that my light switch plug might be missing the pin to the BCM for the auto function.
Is that true for the facelift MK3?
After checking online again I can see that pin 2 missing and that this is required for the auto function to work. I've bought a repair cable (000979009E) so I can onnect the switch to the BCM.
My Leon is RHD (UK), does anyone know if the BCM is located on the drivers side?
