serdar_18fr
1,161
Hi everyone,
I have Beats Audio in my Cupra Ateca and while I'm generally pleased with its sound quality and max output, I have some concerns about it.
First of all, the subwoofer setting seems to have very little effect on the bass level.
Even when I set it from the lowest setting to way up the highest, there's very little change in the actual bass output.
I'm wondering if this is the case for all Ateca/Beats Audio owners, or is your experience with it different than mine ?
Your responses to this one will be greatly appreciated. 🙏
Second question: Does anyone know the diameter of the loudspeakers in doors ?
I looked up the original speakers in parts catalog and found out they are only 2-ohms versions of speakers with 4-ohms in non-Beats cars, so they're nothing special I believe.
I'm considering replacing them with Focal VW kits but there are different sizes of those such as 155, 165 and 180 and I'm not sure which one would be the exact replacement for originals. Other than the impedance, the only information I got from the parts catalog is that all 4 speakers on front and rear doors are the same, it's not like they used bigger ones on the front etc. So I wanted to ask around here before I attempt to remove the door cards and measure them myself.
Best regards,
Serdar
No one using Beats Audio?
I guess Cupra side gets much less views than SEAT side of the forum 😓
  • Wow
Reactions: Tell
hey i have seat ateca with beats but i think is the same system
In my opinion sound is bad (like amp doesn't work on full potential)
If you switch to bluetooth sound is noticable better but you lost AA/Carplay :/
Maybe you have fix now?
Hi, thanks for replying.
I wouldn't say the sound is bad, I don't have a complaint with the sound quality, it's clear and detailed enough for me. The power output is not very strong though, after a certain point, increasing the volume level doesn't seem like doing anything. My biggest concern is the bass setting, as I said in my post. I almost hear no difference between the lowest and highest level and that makes you think like there's a software/hardware problem, hence the question for others using the same system.
I had before seat leon with seat sound system
SSS have 300wat
Beats have 340wat and i think sound is worse than SSS
SSS have 300wat
"Worse" is an unclear description to evaluate the sound. Do you find its max output power weak, or sound isn't clear enough, are basses not powerful enough, or trebles not detailed enough? And actually as I said, I have no problem in those terms. I'm just concerned about a setting which does not seem like doing its job.
Hi, everyone
I've been considering a speaker upgrade for my Beats Audio system.
The speakers installed by factory are very cheap and ordinary ones and their single distinction is having 2-ohms of impedance, not the usual 4-ohms.
While I'm generally happy with the sound quality, I wanted to experience the premium speaker quality.
My current plan is to keep the factory installed Panasonic amplifier and the dual coil 2x1-ohms subwoofer in the trunk, just for now.
Both are very mainstream devices and barely fit for an enthusiastic listener.
So, I researched a bit, decided to stay true to the 2-ohms impedance of woofers on doors.
There are a lot of upgrade paths, some of them are 100% compatible kits, like Focal VW IS 165.
But those are also mainstream speakers, just a little bit better than the original ones.
So I chose a bit more premium ones from Focal, the K2 Power ES 165 KX2E component kit for the front doors, which has separate tweeters like the original ones. No crossover needed, as front has already-separated bass and treble signals.
For rear doors, I chose K2 Power EC 165 KE kit, which is a coaxial one, meaning combined speakers where woofer and tweeter sit together.
As they have their own built-in signal separation logic, and the rear signal in the car is a full range one (no separated bass and treble), there's no need for a crossover again. Factory installed tweeters would be unplugged in this setup.
The only concern is whether they would fit in the doors and not mess with the windows, and also whether tweeters would fit in the original space.
I found an established installer shop near me, and I'll visit them first thing in the morning to discuss my plan and other possibilities.
Later I might consider adding a Focal Fit 9.660 DSP and replacing the subwoofer, but they have to wait for now.
If anybody had a similar upgrade done, I'd like to hear about the experience.
Cheers,
Serdar
