Site Owner
10,795
3,075
South West
www.seatcupra.net
What is it?
The refreshed, performance-focused flagship of CUPRA’s all-electric hatchback. The facelifted CUPRA Born VZ brings enhanced efficiency, revised interior ergonomics, bold exterior updates, and upgraded cabin tech now featuring a 79kWh battery producing 326 PS and 545 Nm of torque.
The big news for the VZ model is a 24-mile range bump, from 366 miles to nearly 390 miles (WLTP), plus a shift to a wider 8J 20-inch wheel setup wrapped in 235mm tyres for improved road-holding.
It’s a hoot to drive, but would I swap it for my 300HP CUPRA Leon? Read on to find out.
Verdict
The facelifted CUPRA Born VZ continues to be one of the most engaging and stylish electric hot hatches on the market. The extra range, wider track setup, restored mechanical steering wheel controls, and clever interior lighting upgrades make it an even stronger package for daily driving. However, a few lingering software gremlins and sound system quirks keep it just shy of perfection...
Continue reading...
Great review and agree with all points, whilst I have not done many miles today the indicator is louder than our Born and I had to play around with the equaliser to get more balanced sound. Tires are Hancock ION EV and the Abarth 600e comes with exactly the same make, model and size of 235 40 R20! The VZ certainly shifts from a standstill to 60 mph and feels planted at speed but a bit softer on the comfort setting than our Born V1 having adaptive dampers. It hides its weight well but feels less pointy than a lighter petrol or EV for that matter but at 2004 Kg is not exactly light.
Currently on charge as I too have some A1, M1 and A14 drives then over to Manchester via the M6 Thursday, so will see if I get similar range and miles per kWh. Door cards, clicky buttons and 10 inch driver screen are the highlights of the new interior with a soft touch on the top of the driver and passenger doors and on the VZ lashing of faux Alcantara, I notice no longer in the V1 and V2. I will see how many bugs I encounter. My first is that I cannot add the car to my Cupra app. VIN registers but won't connect to Cupra backend servers.
Reactions: madtatt and Syphon
A great review.
Thanks for that, Syphon. (y)
It confirms that I made the right choice with my VZ order. I'm really looking forward to driving it, likely in October.
@jezyg
I'm really curious to hear what you have to say about the power consumption and charging times.
Reactions: Syphon and jezyg
A great review.
@jezyg
Will let you know, charged on home charger at 7.4 KwH on Octopus we now get 6 hours cheap rate whenever grid has spare capacity, so I do more regular top up charges, purposely charged to 100% last night. Say's 391 miles of range on the Ohme app. VZ is a top choice more so on the facelift car IMO you won't be disappointed.
Reactions: madtatt
That's great; I'm looking forward to your report. (y)
So after my first 200 mile run I have the following:
Motorway steady 70 3.6 -3.7 mile kWh
Cross country 50-60 mph 4.0 mile kWh
Stop start traffic 3.2-3.4 mile kWh
The VZ is more of a GT than a hot hatch overall, fantastic on a cruise the Hancock ION EV tires reduce tire noise noticeably and at 40 or 50 mph it is so smooth, you think you are only doing 30 mph. The Travel Assist 3.0 is great it will steer and brake even on a windy country road as well as motorway some will like it some will not. On a dark night or unfamiliar roads gets my thumbs up. Other thing I noticed was momentum get the car close to 60 or 70 and the momentum of the car means it will carry on above those speeds even lifting off fully, something you get used to though.
My wife summed it up that compared to her pre-facelift 2025 226 eBoost V1 with the updated infotainment and 12.9 screen the new VZ felt more expensive both to drive and overall interior quality. Yes it has bugs as Scott mentioned, but is a new vehicle and I imagine an early build with all the joys of the immense amount of software EV's have and never get fully bug fixed due to complexity.
@jezyg
Thanks for this initial impression. (y)
It all sounds very promising.
However, I’m a bit confused about the range and consumption figures you mentioned.
You wrote that consumption is 3.7 kWh at 70 mph. But surely you meant that, when driving at 70 mph on the highway, the efficiency worked out to 3.7 miles per kWh, right?
Reactions: jezyg
@jezyg
Yes, apologies 3.6 - 3.7 miles per kWh. Slightly more efficient than our Born overall.
Reactions: madtatt
That’s great—thanks a lot.
The power consumption is actually pretty good.
I’d be particularly interested in the consumption at around 80 mp/h; 130 km/h is the recommended cruising speed here in Germany.
Not full sun light on the aperture lane assist camera rather than front assist impaired ?. I get that on my near 10 year old Ateca with Lane Assist / TSR camera. Beep when facing towards bright sun. It's moaning that its being dazzled by the sun so can't see the traffic signs. On a dry day front assist radar shouldn't be moaning but a sunny day facing the car into bright sun that high definition aperture camera can get moody about shades 😎. Always the same bit of road, sun full ahead low in the horizon.
The field of vision is traffic signs, the white lines and head lights in approaching cars for auto dip. Pass on the matrix lights but probably fed by that.
I suppose they could have mixed their warning messages :eek:.
My final update after a trip to Manchester including the Cupra Cty Garage and I got to finally see the Raval which was a VZ Extreme and have a sit in it and play. Will post some pics and thoughts on the Raval page.
I managed 4.0 kWh a mile on my 78 mile run to and from Manchester the main thing is the Born 2026 even in VZ form is about 0.2 kWh a mile better than our Born V1 230 2025. Brakes are far better would like to see if a standard Born is any better as I do find the current brakes not quite sharp enough and take time to adapt after driving my Ibiza with very sharp brakes.
I do prefer the proper boot release via the badge on our current Born. I find the new button a bit fiddly and others who have tried it have found the same. You do get use to it but on a dark and wet night might not be the easiest to use. Overall the new Born does feel a nicer car existing owners won't find a massive leap more multiple tweaks for a progressive update.
Excellent review and feedback. Having come from an EV I was tempted by the new Born VZ as my introduction to the brand - a great looking car and seems to have hit the sweet spot in terms of power, handling, size and range. It's now got a real presence and premium feel to it with the new nose and interior and I'm sure the wider rubber will work out well. If it wasn't for the pull of one final, noisy, 'end of an era' ICE adventure from the VZ5 it definitely would have been on my shortlist.
It looks well planted on the road.
Like a diesel 😉. The Ateca likes the autobahns and Altea before. They probably know how to deal with the weight and suspension.
Great analogy and spot on, Born is a GT not a hot hatch will be interesting to compare as and when I get a chance to drive in a Raval. With the delays on my Abarth 600e, I am starting to consider canceling and going for a Raval even though it is a bit more monthly wise. I loved it after finally seeing one and getting to sit it it and have play. Why I love my Ibiza - pointy and fun on twisty roads especially when driving in a more spirited fashion.
Reactions: madtatt and Tell
