ifa
35
Estonia.
Hi.
Found it!!! Can you tell me how to fix it? I don't want to use it as a cardholder.
Thanks.
Have you tried adjusting your steering wheel slightly higher or lower that may cure it? Mine buzzes slightly at one particular height and just moving it up a few mm it goes away.
Reactions: ifa
It didn't work with the steering wheel. And with the cards, it's not 100% either.
Thanks for the advice.
The car is three years old and this is happening. I'm afraid to imagine what will happen next. (I'm trying to sell it, but no one is buying it.)
  • Sad
Reactions: Rob66
Your car should be under warranty if I'm not mistaken.
Take it in and describe the issue. I took mine to Tallinn Kristiine Topauto multiple times for various audible issues.
EDIT! Wow new cupras got only 3 years warranty??? insane... I just found out so my suggestion is irrelevant.
I sometimes had to put extra effort in it, record good videos of the audio and describe it very well.
It did happen where they said they can't find it. Try to get videos with clearly noticable sound and describe exactly what you do to make it happen plus how it stops.
On one occasion I went on a drive with the employee to show them myself so they don't tell me im imagining things.
Reactions: Rob66 and ifa
