Right, its been a while so time for an update.
So, the car went back to the
dealer and they replaced both lambda sensors, and as expected this had no effect whatsoever. They then had another look at it and said they checked every single parameter that they could and could not find anything wrong. As the car was tuned they recon they couldn't go deep enough. So i decided to take the car back to VGS in Swindon where it was tuned before I bought it.
However, between me booking it in and taking it, the strangest thing happened.
So on the Sunday I did a fair few miles and as what has been normal since june, the car only averaged around 24mpg. Then on the monday morning I jump in the car and do my usual 12 mile commute to work stuck behind buses and the car, out of nowhere averages 38mpg which is an absolute record for that journey!
On returning to my car at the end of the day it wouldn't bloody start (would not crank). My friends was getting his jump pack out and then it suddenly came to life. Got it home and was going to scan it for codes. However when I turned the ignition back on i got a battery warning. Checked the battery with a meter and only 9v. RAC called and it turns out the battery was the original, so no surprise that it had given up. RAC replaced the battery and all was good.
Car was continuing to be back to normal and averaging mid 30's mpg.
On the Thursday i fuelled up to go to Swindon and the theoretical range had jumped to 320 miles. On the journey there it averaged over 38mpg.
The guys at VGS gave the car a thorough going over checking all parameters, sensors and live data including fuel trims, and said everything was absolutely spot on. They could not explain the issue I have been having with fuel consumption and were just as miffed about it as me.
I didn't expect them to find anything seeing as though the car had somehow fixed itself a few days before!
I then drove over to Wales for a few days and on my return journey it averaged 40.7mpg, which i have never seen before.
I refuelled after 331 miles with an average of 34.6mpg and an indicated 65 miles of fuel left in the tank. The car has also seemingly re-learnt my driving style as after refuelling, the indicated range was saying 375 miles.
I have absolutely no idea what has happened but everything has just suddenly returned to normal - literally over night.
The only thing that has changed is the battery.
It is incredibly bizarre!
