Sep 9, 2026
Hey all
Got an amber check engine light
Code P268100 on OBD
Has flashed up 21 times. and goes up with every small drive
I've heard it can either be Coolant bypass control valve or waterpump
its currently booked in to go mechanics for service and coolant tank change to get rid of dreaded silica bag.
so i guess this errors arrived at a good time.
i just want the mechanic visit to go smoothly so should i acquire a control valve to have in the car incase that is the issue? and could always return it if not.
also i cant seem to find the actual part or an OEM matching quality one?
just got the car , completely stock and low miles , kicking rocks at moment lol any help guidance or recommendation appreciated
EA888 Gen 3
MK3.5 cupra 300.
38k miles
Thanks alot!!
Hi,
That fault code links to your "Coolant system bypass with position sensor" but you don't know if its a faulty valve/sensor or wiring without further testing.
