I did. Used glass glue and OEM double-sided tape. Tape was on the skirts.
That looks epic mate. I’ve bought the skirts and have them at a paint shop. Where did you apply the additional adhesive on the skirt? I want to avoid drilling mine if possible
Appreciate this thread kicked off 3+ years ago - just wondered if anyone has the fitting instructions for these side skirts? I've managed to get my hands on a set but they don't have fitting instructions. I'm on the fence regarding drilling hence I'd like to see what the instructions say
Hi mate. Did you get your skirts fitted? Just wondering if you glued instead of drilling and installing studs?
I was considering fitting some but didn't want to drill into the sills for the studs. I'd be tempted to see how you get on with just adhesive. I ending up just fitting maxton skirts.
These are the instructions I got at the time, including fitting the studs
Reactions: neilg
Thanks for that mate - appreciate you sending those instructions. Skirts are at the body shop getting sprayed now, I'll let you know what option we went for (y)
Reactions: Lucas90
With the Maxton skirts - did you go VHB tape, tiger seal type sealant or end up using screws anyway?
I ending up screwing the maxton side skirts but they screw underneath the car so if you remove them you'll never tell. They are also just little self tappers unlike the official ones than require studs drilled into the sills.
Reactions: scoobyc
