DaveSmith
114
75
Market Rasen, Lincolnshire, UK
I've noticed that since the change in the weather (getting colder) the radiator fan is on when I get home and park up, even after fairly short traffic free drive. For example, tonight I drove about 12 miles on open roads at 50/60 mph and a short bit of town driving at 30mph, so it was not being worked hard. The fan runs on for several minutes even after the car is parked. I don't recall it doing it in the hotter weather earlier this year or at all over the 2 years I have had the car. I have checked the coolant temperature and it is rock steady on 90DegC. I have tried it with a/c on and off and it makes no difference. Checked coolant level and it is OK. Also noticed a marked drop in mpg which might not be related to the issue and just cold weather.
Car is 73 plate 2.0TSI 190 Petrol.
I believe it happens in conjunction with the aux water pump.
When you switch off the car the aux pump keeps pushing water around the turbo so it doesn't cook the oil now sitting still inside it.
The cooling fan comes on to remove the heat.
Reactions: DaveSmith
Maybe it's always done it then? Can't say that I ever noticed it until just recently though.
Maybe it’s the petrol particulate filter performing a forced regeneration to neutralise accumulated particulate matter in the filter; engine fan running and a marked drop in mpg are two of the tell tale signs.
If the cooling fan is running when you reach your destination and switch the ignition off, then the regeneration process is interrupted and will recommence on the next - and subsequent - ignition cycle(s) until the regeneration is complete.
When I had my 2.0 petrol Polo GTI+, other tell tale signs in addition to the two above were;
- a deeper exhaust note
- a ‘hot’ smell from the exhaust
- hesitancy a slight lumpiness when moving away from rest and a slight reluctance to accelerate
- stop start is deactivated
Reactions: trew and DaveSmith
Nail hit squarely on the head I think.
Exhaust note yep, start/stop enabled but not functioning yep, hesitancy yep. I'll check the exhaust smell next run.
You are a steely eyed missile man.
Reactions: SRGTD
Well I did abit of research and it suggested that alternating hard acceleration with coasting is the best way to get it to do its thing. Apparently the coasting allows more oxygen to burn off the carbon.Tried that. Got to my destination and parked up and no fan. Drove home and mpg back up to normal 38mpg instead of low 20's, lumpy idle / hesitation gone and start / stop working again. So that was the issue. Shame the car didn't tell me what it was doing, as it tells me just about everything else.
Reactions: trew and SRGTD
Good to hear it’s sorted and pleased my ‘armchair diagnosis’ was correct.
I’ve posted on other forums the acceleration / coasting method of helping to neutralise the accumulated particulate matter in the GPF. I may be wrong but I think this is the method quoted by Seat and / or Cupra in the owners manuals.
With my last VW which had a GPF, there was nothing in the owners manual on the acceleration / coasting process and no warning lamps or warning messages on the car’s instrument display. No information on the subject was provided by the salesman when I collected the car when new either. Quite a few posts similar to your original post on various forums so it’s seems it’s up to the customer to find out for themselves
A nice little money maker for dealers if customers are getting dealers to investigate and paying the investigation charge, only to be told there’s nothing wrong and what they’ve experienced is normal behaviour 😡.
