The edge is where it makes connection so its the edge... least in mine which has to be kept clean, centre where one pin makes, contact edge the other. Suspect our trusty dealers wear gloves.
I dont use a knife as per this video but a thick headed screwdriver and twist. A bradel to get it to ping out. The guy uses a screwdriver his finger to catch it. This was 2025, same as 2032 edge connectors make the contact so its the edge that needs to be kept clean and the bitter bite sticker removed off the surface if stuck on.
I guess a cheap exhausted battery if a replacement doesn't work. Vag use Panasonic as James pointed out. I use Duracells bought from Amazon main store not their market place seller options.
AI told me to avoid Duracell as they have an extra thin layer of bitter bite coating (plus the sticker) which may somehow reduce the conductivity and shortening the battery's useable life.
Oh, and the new Graphene layer (not graphite). Now I am using a new CR2032 with Graphene technology which is specifically designed for use in key fobs.
The "Superconducting" Matrix: Adding a layer of graphene to the internal electrode structure. Because graphene conducts electricity incredibly fast, it lowers internal resistance and ensures a steady, powerful signal even when a device is far from its receiver.
Other major brands like Duracell, Energizer and Panasonic still stick with using Graphite only in their dated designs.
