Have you tried individual mode to configure it how you'd like? our review car has gone back so I can't test it, but it should let you choose the fake sound level.
Formentors they would pull off the lead to the soundkator where you could do it by coding on a Raval. You could on the Formentor.
Tried individual mode - still can't disable 'smart regen'. Yes you can disable 'cupra noise'.
Not so Smart regen. Perhaps they think you dont need to. Anything on the sister cars ?.
This hybrid thread doesn't give any ideas?.
You can turn off the smart regen A. It will then stay on the number setting you use until you use a paddle to adjust it.
It in the assist settings not sure what they call it i will pop out and have a look later and post more info.
You can also choose between high and low regen in the setting . This will double the amount of regen setting available.
Hi Keeff,
Snap - same colour. I've looked in the Assist Setting. I'm not going outside - it's STILL raining.
If you are in Dorset I will keep an eye out I live near Wimborne.
We drive in D mode number 3 low regen setting .
I like one peddle but I dive an old id buzz its about the same as the buzz’s b mode .
Reactions: Syphon and Tell
Regarding the one pedal regen/braking, i have yet to discover about brake lights turning on or not, because at the 'agressive' regen (i get 2 choices on the display menu) in B mode, the car feels like actual braking at 50% by just lifting the accel... i mean, it's so strong i fear the car behind might not perceive it fast enough if the brake lights are off! So, i really hope they show up with a deceleration similar to braking, but so far i haven't tested it 🙏
My sweet spot for city and open road drives is B mode set on level 1... it flows and holds just right.
The D mode can also be quite fun once comfortable with the paddles. I drove down a whole mountain controlling speed with just the paddles, no brakes or accelerator needed, really cool 🤓
So far the kWh use in the city is ridiculous... i get back home with 1-2% less on battery after 10-15 km, so the regen actually works!
Reactions: Tell and Syphon
I wonder, is it really so that Raval misses the option to disable folding mirrors? I didn't see any mention of it in the manual but perhaps I looked at the wrong spot? Typically I disable this feature for winters here, afraid ice might break the motor if unlucky. All cars I've looked at have had the option to disable them so far so this would be a first if not. Typically for me folding mirrors functionality lasts around 5 years, then it will start having trouble folding to the right position, this was quite accurate for my last 2 cars.
If you could manually fold them wouldn't be a problem but seems like it's only meant to be electricly operated according to manual so won't give it a try. My Honda Civic I could fold manually even if obviously it was electrically operated too so in the end I tend to fold them manually when going to car wash. With Mazda 3 you couldn't manually fold them so stopped using the folding setting when the folding wasn't always dependable any longer, the motor was restricting any manual movement so better leave it be once it managed to fold fully back (with a bit help of special lubcricant contact spray). lol
EDIT: I did see a mention when searching on the net that some settings may be hidden if engine is turned off, could be I was browsing the settings with car turned off, will have another look tomorrow, only had two options, synchronous mirrors and fold mirror when in reverse which I also learned now how to adjust, basically:
Turn car on, put in reverse, adjust the mirror how you want it, put back in neutral, turn off and should now be saved. Also the mirror selector has to be in the right setting, in "R" in rest of the europe and "L" I suppose in UK for it to work. Seems pretty advanced for something that probably could be done easier. In my Mazda I simply adjusted the mirror how I wanted it to be when in reverse while it folds down, a little bit simpler. :p
  • Sad
Reactions: Tell
Unfortunately didn't show up any mirror folding disable setting. Should be under Vehicle settings -> Exterior -> Mirrors but yea it's missing, Born has the option there.
Guess I'll give Cupra feedback about it if they could add in a firmware update possibly. (Feedback was already submitted onwards)
Reactions: Tell
This would be where if you could still code these cars (assume you cant) you'd code it. I coded the Ateca to do mirrors in on lock. For about two years they were shipped with the menu item missing, just needed enabling... but suspect you can't. I haven't researched coding this range of cars.
BTW it doesn't have the old hang onto the Kessy button for 3 seconds to get them to fold in. That was the idiosyncratic way they had on the first implementation of Kessy on Seats 10 years ago before they brought lock and mirrors in, on the infotainment screen, 2 years later. The oddball working on that may be back...
Today when I browsed to the vehicle locking settings, lo and behold, there folding mirror setting was found! 😂 Turns out Born and Raval devs had different logical thinking. 🤔 My brain is more siding with Born devs' too. 😅
Reactions: Tell
CUPRA brake lights do not trigger at a fixed regen percentage on the charge meter—they are governed by deceleration rate (g-force) under UN/ECE Regulation No. 13-H, which Volkswagen Group vehicles follow.
Deceleration Thresholds (UN/ECE Regulation No. 13-H)
    • ≤ 0.7 m/s² (approx. ≤ 0.07g): Brake lights must not turn on. Light regen or coasting stays in this zone.
    • > 0.7 m/s² to ≤ 1.3 m/s² (approx. 0.07g–0.13g): Brake lights may illuminate depending on vehicle calibration and conditions.
    • > 1.3 m/s² (approx. > 0.13g): Brake lights must illuminate. Lifting off the throttle in B mode or under stronger regen will typically cross this threshold.
Reactions: Tell
I reckon you could give a little brake light blip then take your foot off if you were worried about cars not knowing what you were doing or just leave it to automatic as above and not worry. Bit like those that dont indicate :oops:
In the Raval, I've found that B mode gives a near-perfect control with one-pedal driving, right down to stopping. If I accidentally touch the brake while lifting off, it feels like it's going into a stall and takes second or two to pick up again. It's very unnerving so I much prefer to simply use one pedal unless I really have to brake sharply.
It's just one of those things where you develop your own preferences with your own vehicle, but the brake lights do work. Honest! :)
Reactions: Tell
It's still up in the air for me whether to B or D. :p I keep switching between the two everytime. For me I wish the B ideally gave a little bit smoother of a stop, it feels pretty abrupt stop unless you very gently lift the pedal but the feel isn't there in the same way as braking in D mode though. I feel the recuperation is a bit aggressive at times when I'm the guy who tends to smoothly glide to stops in an ICE manual car lifting the pedal quite early and very gently braking as needed. The braking aspect in D mode feels brilliant again, I like how the brakes feels like in this car, don't grip too much, it feels just right and has that pleasant mechanical feel to it. While it almost feels useless to use brakes while in B mode unless you have to make an abrupt stop and much of that "feel" is gone. You win some convenience but perhaps miss out on some of that engaging feel the braking gives you. I'd say I slightly enjoy more driving in D mode if I was forced to pick a mode because "having to" brake and experience the nice feel of it. My Honda Civic Sport 1.8l HB gave me that kind of satisfying braking feel as well, so I ended up often very gently braking coming to stop to experience that satisfying feel (like listening to ASMR but a different sensitory experience idk?)
