Feb 2, 2025
I have a Seat Ibiza 6J 2011. I installed 2 new front speakers today, as one of my front speakers was experiencing a crackling noise. I was wondering if I wired the speakers correctly. I wired the brown and red wire to positive and the red wire to negative, as from a few threads and what videos I could find online, connector position 1+2 was positive and 3+4 was negative. Could anyone who knows/has a wiring diagram chime in to confirm that the orientation of the wires is correct? I did both speakers with the same orientation, so it shouldn't make too much of a difference either way, but I was considering installing rear speakers sometime soon, so I would like to get the correct polarity.
Here is the connector (image is from another thread as I did not take a photo when installing):
Hi mate did you ever get any further with this?
I believe the way I described was correct; both work perfectly. I think you can use a voltage tester or multimeter to identify the positive wire, but as long as both sides are wired the same, they will be in phase with each other anyway. Or test the speakers before you put it back together using the radio.
Reactions: HarryDA
