val
Apr 6, 2026
Any help/pointers will be greatly appreciated. Going a bit crazy here. Replaced master cylinder, plastic connector on the metal hydraulic hose, tried with small rubber o-ring and a cup-shaped piece, but still see fluid leaking. Which type of seal should be on master-side? Thanks in advance/.
not sure if you managed to fix the issue, but I had same problem. In the end I put a bit of ptfe tape around metal hose, then connector on top with top hat rubber seal.
