Pricey_89
21
Wales
Evening!
Has anyone upped the tyre profile on a their LCR ST's or LCR's 19 inch alloys?
I'm looking to add some more protection for potholes as I've managed to crack one of my alloys :cautious:. Just wondering if anyone has done this already and did you have any clearance problems with the wheel arches or shocks with the camber factored in at the rear?
I'm aware the ride height and the speedo will be different but my cars dash shows 2mph over the cars actual speed (Checked with GPS at a range of speeds with newish tyres) so the difference would bring me to pretty much accurate with the tyre change.
Thanks all!
If I look at my 2015 with stock suspension & stock wheels, I suspect I have more than enough room to accomodate the extra height.
Tyre size calculator shows that sidewall would be 13mm higher
235/35/19 Maxxis tyres
AP1GczO0NWoSu0Y7uAwLW50hdfimMRFlGhRcU4K_TdHPZI5meoESIkzCDEXUGEjhaRhwQdYmdsfFaHAYh83wzRiPrjAdo96X8muB2VL3IcZBGGyo7ucGQb57rUAYUpst01J6QJ3e9leh6uh6C2hTwrHF17JPyA=w1920-h1080-s-no
235/35/19 Vredestein tyres
AP1GczNLig3yDrPXhNrGmTHLJ2ZRV7Ooco6Gy0r5-6_9UaFKOb9fdwoYAZ_K7FLINaGW_sBX9MEEmxwTHAnRuW_9fyWGPXl1OP6jLity2AsdxBf-UBFhBxulRpTC61m5FD6wM_bMiWO7ci7zwpHpw1napcoN1Q=w1920-h1080-s-no
It will affect the accuracy of your speedometer and may cause rubbing issues.
Why not go down a wheel size and up a profile which should result in a wheel/tyre combination with the same circumference as the original.
Reactions: SRGTD
