Happy Ant
70
16
Does anybody know where the battery ground point is on a new Leon MHEV automatic as I need to bypass the negative battery terminal due to the BMS?, thanks
In the boot, Under the carpet, towards the seats on the left hand side.
I wouldn't be messing about with it, you could end up with a plethora of faults.
Is there not one behind where the battery would usually be, on the right hand side in the engine bay against the firewall - near the scuttle panel?
Usually just a bent piece of metal with a few ground wires attached
There should be a positive terminal inside the fusebox, again on the right hand side in the engine bay (far right, against the wing)
Reactions: Happy Ant
