Nov 3, 2026
I keep getting about 0.2-0.25 bar underboost starting at 4000 rpm in 3rd gear and I cannot figure out exactly why. I'd like some advice on what the cause is. I hope it's just a flow issue from the intake, but I don't know anyone who can help me test it. I'm hoping someone has the time and is willing to help me out with this. I'm located in The Netherlands. I've posted a table with my boost measurements, maybe someone recognizes the issue in this from experience and can help me out that way.
RPMBoost demandBoost actualAverage shortage
3800–4000 rpm2,421 bar2,408 bar0,013 bar
4000–4500 rpm2,543 bar2,533 bar0,009 bar
4500–5000 rpm2,542 bar2,300 bar0,242 bar
5000–5500 rpm2,543 bar2,303 bar0,240 bar
5500–6000 rpm2,520 bar2,329 bar0,191 bar
6000–6500 rpm2,510 bar2,353 bar0,157 bar
Thanks for taking the time reading about my issue.
Which intake do you have? OEM or aftermarket (if so, which one).
Can you check your wastegate Duty cycle as well (requested vs actual)
Reactions: nd-photo.nl
For that fault code P0299 check your:
Turbo bypass solenoid,
MAP and air temp sensor,
Boost pressure sensor with air temperature sensor.
