Buyer's guide CUPRA Formentor Buyer's Guide
Overview​
The CUPRA Formentor is the brand’s first standalone model, launched in 2020. It combines coupé-SUV styling with sharp handling and a wide range of petrol, plug-in hybrid, and performance engines. It’s aimed at buyers who want something sportier and more distinctive than a VW Tiguan or Audi Q3.
Key Specs at a Glance​
  • Body style: Coupé-SUV (5 doors, five seats)
  • Boot space: 420–450 litres (depending on drivetrain)
  • Engines: 1.5 TSI, 2.0 TSI, 1.4 e-Hybrid PHEV, 2.5 TSI 5-cylinder (VZ5 – limited edition)
  • Power outputs: 150hp – 390hp
  • 0–62mph: 6.8s (310hp AWD) – 4.2s (VZ5)
  • Transmissions: 6-speed manual (1.5), 7-speed DSG auto
  • Drive: FWD or 4Drive (AWD)
Trim Levels (UK)​
  • V1 – entry level, good spec (18" alloys, LED lights, digital cockpit).
  • V2 – adds larger alloys, leather upholstery, and heated seats.
  • VZ1 / VZ2 / VZ3 – sportier trims with upgraded suspension, Brembo brakes (VZ2+), and adaptive chassis.
  • VZ5 – limited edition, 390hp 5-cyl, not available in UK unless imported.
Pros​
  • Striking design, stands out in the SUV crowd.
  • Wide engine choice (economical 1.5, plug-in hybrid, or high-performance 310hp/390hp).
  • Good balance of handling and comfort.
  • Well-equipped, even in V1 spec.
  • Strong community support and resources.
Cons​
  • Infotainment system can be buggy and slow.
  • Touch-sensitive controls (volume, climate) are divisive.
  • Rear seat space is tighter than rivals.
  • Residual values still settling – PCP/lease can be better than outright buy.
Formentor Used Buyer’s Guide: What to Look Out For​
From owner reports on our Formentor Forum, here are the main things to check when buying used:
Common Issues Reported by Owners​
  • Infotainment & software glitches – screen freezing, laggy response, random resets. Make sure a dealer has applied all software updates.
  • Battery drain – some owners report flat batteries after short journeys or long periods parked. Check the history for battery replacement or updates.
  • Interior rattles & trim noises – especially around the dashboard and door cards. Test drive on a bumpy road.
  • DSG gearbox behaviour – occasional hesitation or jerky low-speed changes. Ensure it has smooth engagement and regular servicing.
  • Tyre wear – mainly on higher-powered AWD versions. Uneven wear can hint at alignment issues.
  • PHEV models – check charging port operation, charging cable condition, and hybrid range (should be around 30 miles when new).
Buying Tips​
  • Service history – CUPRA recommends annual servicing. Ask for receipts, not just a stamped book.
  • Warranty – new cars had a 3-year/60,000-mile warranty. Later models can have extended warranties (5 years). Confirm if any coverage remains.
  • Recalls & software updates – CUPRA issued updates for infotainment and electrics. Ask if they’ve been carried out.
  • Test drive thoroughly – check steering feel, listen for suspension knocks, confirm all driver aids (adaptive cruise, lane assist, parking sensors) work properly.
  • Tyres & brakes – high-performance trims can quickly consume consumables. Factor replacements into the budget.
Verdict​
The CUPRA Formentor offers style and performance rarely seen in this segment. As a new buy, the V2 or VZ2 trims offer the best balance of spec and value. As a used buy, look for cars with full dealer history and proof of software updates.
Extra information and resources​
Reactions: xxup
Author
Views
4,566
First release
Last update
More resources from Syphon
