Is this the clutch inspection hole?? Pics included.
Bogwoppit
1,085
Lincs
Before I pour loads of soapy water down this hole can someone please confirm it is the correct hole, I got this advice from this thread, 18th post:
http://www.seatcupra.net/forums/showthread.php?t=88263&highlight=g60+clutch
Please help, it is the last thing I want to try before ordering a new clutch.
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
rather you than me...
but yes - that will 'get' you to the clutch - not sure there's anywhere for it to drain out
the purpose of the hole is to use the flywheel as a tacho
acidstrato
My Fast says shut up!
Dec 9, 2004
5,942
Newport, South Wales
when i was faced with this i decided not to do it as it some how didn't seem right
afterwards i was glad i didn't as my suspicions were correct and my clutch plate was as smooth as a babies bottom.
from then on clutch slip was obvious to me, and the difference between the odd slip which sometimes confused with surging issues and constant slipping as a result of a worn clutch
Bogwoppit
1,085
Lincs
I have just tried the soapy water trick and it didn't work on my car, it made a slight improvement but it is still slipping.
Time to bite the bullet and cough up for a new clutch.
Thanks for your help.
SWANSWAY CUPRA Dealership
