312mm discs on 16"s
danmarley
18
Hi Guys,
found this conversion kit for the Tdi,
https://sslrelay.com/s74326199.onea...nid=1546156de847fad/shopdata/index.shopscript
found discs as well, just wondering if anyone has put the 312mm discs on with 16's??:shrug:
I'd like to upgrade as the discs need changing anyway, but if I have to fork out ££££'s on 17" or 18"'s not worth it!! I've seen an FR on here with the upgrade discs and standard alloys so might fit???
Any suggestions??
Thanks Guys
Renda
141
Zagreb, Croatia
They fit on 16"s, but might still depend on the wheel itself, and how much room it has underneath... And of course on the offset (the wheels in the pictures are et42 - with bigger offsets there shouldn't be any problems!)
Which wheels do you have?
Jordan20vt
Mk3 20VT
Jan 14, 2006
256
Rugby
jesus thats tight!!!
danmarley
18
Got the sport alloy's pictured so they should fit fine!:funk:
It is a close fit but that looks cool! Thanks for the pics!!
What size spacers are you running on the front? are you useing hubcentric ones?
gazjones
if you have 256 front brakes (fsIII) then you need new hubs.
Triple D
Did you forget mine jord?
danmarley
18
they do not need different calipers they are designed as 'plug and play' swap over to 312mm discs.
techie
Skoda Techie
Mar 22, 2003
5,438
Worcs
FSIII is the model name of the caliper for the non Sport brakes that need new bearing carriers etc.
mexicorich
Newbie
Apr 17, 2006
261
Hartlepool
So is that conclusive?
I can't just get away with these brackets to space the original calipers on my 130 out 12mm to fit 312 discs?
techie
Skoda Techie
Mar 22, 2003
5,438
Worcs
As Sisson and Gaz have said, the calipers are a different make and design so they dont just swap over.
The original caliper is on the left (Lucus) the 312mm is on the right (ATE)
