Red Cupra GT2871R
Jonny95 SXE
The Irish Contender
Nov 23, 2004
339
Well this is my new bus, 1.8 20V Turbo,
a few from sunday:
The spec is a s follows....
Seat Ibiza Cupra Mk3
1.8 Turbo
Roja red (later found out to be Flash Red in the UK same paint code)
Color coded
Suspension Setup:
Coilovers - FK Konigsport Silverline X Fully Adjustable S/S Suspension.
Uprated springs.
Neuspeed front uprated antiroll bar
Neuspeed rear uprated antiroll bar
Momo Seat Sport Strut Brace
Eibach 15mm Spacers Rear
Custom 4mm Spacers Front
Fully Polybushed.
Professionally Counter balanced and corner weighted at northampton motorsport.
Wheels:
Team Dynamics pro Race 17x9 with et35 (front) et37 (rear) one off lightweight wheels from Rimstock
Toyo Proxies T1-R 215-40 Tyres
Brakes:
Brembo 4 pot Callipers
305mm Brembo Vented Discs
Ferodo DS2500 Racing Pads
Braided Stainless Steel Brake Lines
Brembo Rear Discs & Pads
Engine:
AYP 1.8 20V engine
CatCam Rods
ACL Calico Bearings
Carbon Fibre engine cover.
AET Garret GT2871R Hybrid turbo
Stainless steel custom CupraCup exhaust manifold.
Porsche GT3RS 620CC injectors.
Vibra Technics engine mounts
Custom Stage 2 17 core Single Pass FMIC
Aluminium Mandrel Bent 2.5" IC Pipework
3" Aluminium Aluminium Turbo Inlet Pipe
N249 Removal Kit
Bailey DV30 Recirculation Dump Valve
Cold Side DV Relocation Kit
Optima red top race battery
Battery Relocation Kit (now in boot)
EvoShield Inlet Gasket
Samco Sport Silicone Hosing
Green Cotton Filter
S4 Air Flow Meter Housing
S4 MAF element.
Leon Cupra R Map Sensor
S3 fuel pump
Walbro 255LPH inline helper fuel pump
Aluminium catch tank
Aluminium power steering tank.
3" Custom Stainless Downpipe with temp and wide band lambda sensors
100cell Race Cat
2.5" Blue Flame Cat back exhaust system
Manifold, turbo, turbo vanes, compressor, downpipe and CAT coated with thermal resistant ceramics.
Post run water-cooling.
Custom post run pump timer
Aluminium 10 core oil cooler.
Ngk Iridiums Ix (bkr9eix)
Tuned/remapped by Jabbasport
In car boost controller.
Liquigauge 2.5" lcd guage - 0-100 timer, bhp calculator, digital clocks, fault code removal, map adation, TB reset
N2MB 2 stage launch control
N2MB flat out shift
Retro fitted cruise control
Drivetrain:
Spec Stage 4 Hybrid 6 Puck Clutch (Kennedy Racing)
Billet Steel Dualmass flywheel (Kennedy Racing)
Rebuilt 02j gearbox
Upgraded Traction Control Program (S3)
Audio:
Infinity Kappa 6x9’s
Sony's up front
Stealth acoustic shelf
Alpine 4 channel 600W amp
Iphone Itouch AD2P Audio bluetooth link
Exterior:
Stubby drivers side mirror fitted
Front bumper altered to fit intercooler
Cupra R headlights
Cupra R repeaters
Leon Cupra R splitter
4.7k HID's
LED Park lamps
9,335
South Wales
Awesome fair play.
I take it your downpipe goes down the passenger side, what manifold are you using for that? Was it difficult to do?
And what catch tank and power steering tanks are those?
Jonny95 SXE
The Irish Contender
Nov 23, 2004
339
thanks guys.
The mani is custom, and actually has good clearance from the firwall, turbo can come off with the head on and can be tightened quite easily.
yep, DP on passenger side.
the catch tanks are spurious from merlin... any performace/rally center can get them for you
dozza.13
PS3 Tag - Dozza1979
Jun 30, 2006
1,082
Grimsby
Looks awesome mate, is that the standard red or u had it resprayed? How much power is it putting out? Is that a ring sticker i see on the back?? ;)
ian_cupra
stunning car, looks so shiney!!
i think i do spot a ring sticker on the back there!
must be pushing a fair bit of power out :)
Jonny95 SXE
The Irish Contender
Nov 23, 2004
339
thanks for the comments guys!
yeah its the original red and yup there is a ring sticker on the back but from a previous owner :(
nice to see some active Irish members ere too James.
Jon
