Error codes
Hi guys just wondering if you have had any more problems with this?
What happened to me was i turned on my lights to full beam and on the dash the hand brake light started to flash, abs light and traction control light came on and stayed on. Obviously did the initial thing and shat my pants! Stopped the car turned the engine off, and when i restarted it had gone, but then came back when turning the main beams back on.
Now not sure if it is related but i currently have HID lights on mains and dipped and they have been nothing but a pain, have gone though 4 ballasts so far under warranty (they have been installed for 2 months), earlier on in the day a ballast went on the main beam light and it is still the same.......not sure if it is related or if it is possible for it to be related.
So have been driving the last few days just on dips, last night tried again with the main beams (still one main beam out) and it was fine. Did a vag-com and came up with these...........
VAG-COM Version: Release 409.1-S
Chassis Type: 1M - Seat Leon
Scan: 01,02,03,08,15,17,19,22,35,46,56
Address 01: Engine
Controller: 1ML 906 032
Component: 1.8l R4/5VT 0001
Coding: 10510
Shop #: WSC 79664
1 Fault Found:
18057 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes
Controller: 8N0 907 379 G
Component: ESP FRONT MK60 0101
Coding: 0019469
Shop #: WSC 00001
3 Faults Found:
00813 - Sensor 2 for Brake Pressure (G214)
012 - Electrical Fault in Circuit - Intermittent
00003 - Shareware Version. To Decode all DTCs
014 - Please Register/Activate - Intermittent
01435 - Shareware Version. To Decode all DTCs
012 - Please Register/Activate
i have read this post and checked all codes on "ross-tech wiki", the reason why i'm asking on here is that i see it was mentioned about the electromagnetic discharge with "NIME", just wondering if this could be possible with the HIDS?
I appreciate the time it has taken to read this and any input is appreciated.
Andy
