Scangauge II / XGauge Coding
xd-data-ii
375
San Diego
Following on from this thread
http://www.seatcupra.net/forums/showthread.php?p=1915980#post1915980
bHP Gauge
TXD: 00
RXF: 400080000000
RXD: 0000
MTH: 000A00170000 - for petrol car
MTH: 000A00240000 - for diesel car
Confirmed working - bHP
MAF Gauge
TXD: 686AF10110
RXF: 044145100000
RXD: 2810
MTH: 000100010000
Confirmed working - displayed in g/s
Km/h Gauge
TXD: 686AF1010D
RXF: 0441050D0000
RXD: 2808
MTH: 000100010000
Confirmed working - if you want kilometers per hour displayed with the scangauge set to Miles. Useful for me anyway as speedo is in miles but speed limit here here is in km/h
To take into account any speed calibrations made (-2 seems to be a common setting for the Leons) the MTH function becomes
for -3%=> MTH: 006100640000
for -4%=> MTH: 006000640000
for -2%=> MTH: 006200640000
for -1%=> MTH: 006300640000
m/s Gauge
TXD: 686AF1010D
RXF: 0441050D0000
RXD: 2808
MTH: 001400480000
Works but MTH formating of decimal point in the codes needs sorting, will correct it soon
Calibration factor cannot be taken into account in the calculations
ft/s Gauge
TXD: 686AF1010D
RXF: 0441050D0000
RXD: 2808
MTH: 03BC04190000
Km/H - m/s - ft/s -> you cannot display more than one of these at the same time in the gauge function
Set Tank average MPG as a gauge
TXD: 04
RXF: 800000000000
RXD: 0000
MTH: 000000000000
Confirmed working - see manual for more options on this
bHP reading hit 224 for me today. Pretty damn happy with that.
Km/h seems +1 or 2 Km/H above climate control reading. Will verify which is the exact with a sat nav later.
xd-data-ii
375
San Diego
Boost - MAP
TXD: 686AF1010B
RXF: 0441850B0000
RXD: 2808
MTH: 00910064FF71
Confirmed to work on Diesels only - measured in PSI. Does not work on Petrol cars as they do not utilise the MAP sensor PID
When get working set FF71 to 0000. Note reading at idle. take that and get it converted to 2s compliment then change the FF71 to this.
Transmission Temperature
TXD: 686AF10105
RXF: 031A04410505
RXD: 2808
MTH: 00090005FFD8 - to display in Fahrenheit
MTH: 000100010000 - to display in Celcius
Confirmed working
Coolant Temperature
TXD: 686AF10105
RXF: 031004410505
RXD: 2808
Confirmed working
Am gonna work on getting Boost working.
Also to get Torque displaying
jonathanp
736
Coventry
cool, already got the BHP one but been looking for a MAP one for while, will have to have a go at setting it this week. Might need a little help though as instructions are a little bit confusing
BTW what do you think off the accuracy of the BHP gauge? I've had mine showing 293bhp pretty consistently but I know my car is nowhere near that, 270bhp tops I would of thought.
although it proved useful the other day as the car has been feeling slow/held back since a cambelt service and other bits, this is somewhat reflected by the scanguage now showing 260bhp
andy15star
825
Durham
Hi,
On Lee's codes, it says "see chart below" (see number 1 for example), but there's no chart there, is there a link to the table it refers to ?
Regards,
Andy
Manney
My standard 180 bhp cupra just recorded 230 bhp. That can never be right. How does it measure the bhp?
:confused:
xd-data-ii
375
San Diego
2.25g/s and 3.6bhp when idle.
Havent really tried reading the max maf reading as well as the bhp reading when flooring it. Will take a look.
andy15star
825
Durham
Hi, Just a theoretical query really. If (when set to imperial) the ScanGauge can do km/h with Km/h Gauge
TXD: 686AF1010D
RXF: 0441050D0000
RXD: 2808
MTH: 000100010000
Then how could i get it to read metres/sec ? (or for that matter feet/sec) ??
I know there needs to be something done to the MTH settings, but i'm not sure how the MTH coding works. I could probably work it out for myself if i knew what binary to stick in the MTH line of the ScanGauge.
Best Regards
Andrew
xd-data-ii
375
San Diego
Yeah i plan to look like Im doing work this morning whilst trying to figure out how to work out 2s complement etc for the MTHs function as realised yesterday for the km/h reading it is not taking into account the calibrated speed setting ie. the -3 used.
Anyway, for the MTH 000100010000
0001 (<-Multiply by) 0001 (<-divide by) 0000 (<-add/subtract)
So Im guessing to adjust the km/h reading to a -3 setting
MTH: 00010001FFFD
Will look more into the other conversion later
andy15star
825
Durham
Hi, please forgive my ignorance here!. I was trying to work out how to set up a gauge for speed in metres/sec (or feet/sec).
I understand that the MAF line needs to be set correctly. Working on xdata's figures "Convert Celsius reading to Fahrenheit is 00090005FFD8", i get the 0009 bit (multiply by 9), i get the 0005 bit (divide by 5), but i don't get the FFD8 bit ?. How does FFD8 equal -32 ?. Are these figures Hex figures ?. Converting FFD8 to decimal, i get 65496 !
Again, please xcuse my ignorance !
Andy
