2012 Seat Ibiza - Security Code issue
Jamie_B
DERV
Oct 14, 2004
38
Ayrshire
Hi,
Anybody got any ideas why I don't get a popup box with the security code when i'm trying to calibrate my Steering Angle Sensor?
I get it in all other sections but nothing in there and obviously I need it to be able to start the calibration.
Here's a scan if that's any use to anyone?
Code:
Tuesday,11,June,2019,11:07:32:25280
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.0.2 (x64)  HEX-V2 CB: 0.4505.4
Data version: 20190529 DS308.0
www.Ross-Tech.com
VIN: VSSZZZ6JZDR082683   License Plate:
Chassis Type: 6J-SE25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 44 4B 56
VIN: VSSZZZ6JZDR082683   Mileage: 91120km-56619miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
4B-Multifunc. Module -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 LE    HW: 03L 906 023 Q
   Component: R4 1.6l TDI   H33 9978
   Revision: --H33---    Serial number:
   Coding: 00114016002500080000
   Shop #: WSC 131071 102 209715
   ASAM Dataset: EV_ECM16TDI02103L906023LE 003011
   ROD: EV_ECM16TDI02103L906023LL.rod
   VCID: 74B1DFB4AE3D03A7DE9-8020
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 BE    HW: 6R0 907 379 AF
   Component: ESP8.2i front H05 0001
   Revision: --------
   Coding: 130248DB817500B4C82B12EA81D400821400
   Shop #: WSC 00788 648 00255
   VCID: 025D896CE4493D17DC5-8056
2 Faults Found:
01435 - Brake Pressure Sensor 1 (G201)
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 80
                    Mileage: 91120 km
                    Time Indication: 0
                    Date: 2013.11.01
                    Time: 10:57:59
             Freeze Frame:
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Hex Value: 0x1290
                    Hex Value: 0x2DB2
                    Hex Value: 0x09A7
                    Hex Value: 0x8F7D
                    Hex Value: 0x81F8
00778 - Steering Angle Sensor (G85)
            005 - No or Incorrect Basic Setting / Adaptation
             Freeze Frame:
                    Fault Status: 01100101
                    Fault Priority: 0
                    Fault Frequency: 2
                    Reset counter: 40
                    Mileage: 91120 km
                    Time Indication: 0
                    Date: 2013.11.01
                    Time: 10:59:09
             Freeze Frame:
                    Hex Value: 0x0002
                    Hex Value: 0x0002
                    Hex Value: 0x3251
                    Hex Value: 0x1BB1
                    Hex Value: 0x007C
                    Hex Value: 0x7F7F
                    Hex Value: 0x7FFF
Address 04: Steering Angle (G085)       Labels:* 6R0-959-654.clb
   Part No SW: 6R0 959 654     HW: 6R0 959 654
   Component: LENKW.SENSOR  H06 0060
   Serial number: 090465LGL0009A
   Coding: 01
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_LWSKLOVW25X 005001
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EA5FD9C907159F7B8D-802A
1 Fault Found:
1140738 - Steering angle sensor
          B1168 54 [009] - Missing Calibration / Basic Setting
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 40
                    Mileage: 91119 km
                    Date: 2019.06.11
                    Time: 10:50:08
                    Voltage terminal 15: 14.00 V
                    Voltage terminal 30: 14.25 V
                    Terminal 15 status: On
Address 08: Auto HVAC        Labels: 6J0-820-045.clb
   Part No SW: 6J0 820 045 A    HW: 6J0 820 045 A
   Component: J301  Klimaanlage   0330
   Revision: 00 26 08    Serial number: 0000002542340-
   Shop #: WSC 06402 785 00200
   VCID: 2411EFF452DDD3278E9-8070
Address 09: Cent. Elect. (J519)       Labels:. 6R0-937-08x-09.clb
   Part No SW: 6R0 937 087 K    HW: 6R0 937 087
   Component: BCM PQ25 H+4  H46 0254
   Revision: BF046001    Serial number: 0434 195120431
   Coding: 24882BE88861250092200EF06E0B0CC8008043EC608C2040200000000000
   Shop #: WSC 64564 324 38760
   VCID: 45D75270B5A7CA2FB97-8010
   Subsystem 1 - Part No SW: 6R0 959 802 M    HW: 6R0 959 802 M  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  002 3110
   Serial number: --------------------
   Coding: 030000
   Subsystem 2 - Part No SW: 6R0 959 801 P    HW: 6R0 959 801 P  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  002 3110
   Coding: 020000
   Subsystem 3 - Part No: 1K8 951 171 A
   Component: DWA-Sensor 00  001 0103
   Coding: 000000
   Subsystem 4 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO  H05 1501
   Coding: 000000
   Subsystem 5 - Part No: 1K8 951 171 A
   Coding: 000000
Address 15: Airbags (J234)       Labels:| 5K0-959-655.clb
   Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
   Component: VW10AirbagA0D H10 0020
   Revision: --------    Serial number: 003GX01AXG3T
   Coding: 003044
   Shop #: WSC 06401 785 00200
   ASAM Dataset: EV_AirbaVW10BPAVW250 A01001
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4ACD614C9C392557545-801E
   Crash sensor for side airbag: driver side:
   Serial number: 3495RRB400G4UHC4B93O
   Crash sensor for side airbag: front passenger side:
   Serial number: 3505RRB400G4UHC4JOC5
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
   Part No SW: 6J0 920 904 C    HW: 6J0 920 904 C
   Component: KOMBI         H04 0508
   Serial number: 00000000000000
   Coding: 410A00
   Shop #: WSC 131071 1023 2097151
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
   ROD: EV_Kombi_UDS_VDD_RM09_SK46.rod
   VCID: 2B0304C833831C5F4F3-807E
Address 19: CAN Gateway (J533)       Labels:. 6N0-909-901-6R.clb
   Part No SW: 6N0 909 901     HW: 6R0 937 087
   Component: GW-K-CAN TP20 H46 0254
   Revision: BF046001
   Coding: 022300
   VCID: 70B9D3A4DAA53F873A1-8024
Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H04 0508
   Serial number:
   Coding: 000000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A8DC1CCFCF9C557745-803E
Address 44: Steering Assist        Labels: 6Q0-423-156.clb
   Part No: 6R0 423 156 B
   Component: LenkhilfeTRW        V277
   Coding: 11220
   Shop #: WSC 06402
   VCID: 2F3B10D80E5B607F63B-807A
Address 4B: Multifunc. Module        Labels: 6J0-959-441.clb
   Part No: 6J0 959 441
   Component: MF-Modul       0007 0001
   Coding: 0000001
   Shop #: WSC 77005 000 00000
   VCID: 70B9D3A4D6A53F873A1-8024
Address 56: Radio (J503)       Labels: None
   Part No SW: 6J2 035 153 H    HW: 6J2 035 153 H
   Component: Radio         H15 0302
   Revision: R0000000    Serial number: SEZAZ2M4945439
   Coding: 0503020002
   Shop #: WSC 04941 000 00000
   VCID: 2B0304C833031C5F4F3-807E
1 Fault Found:
00856 - Radio Antenna
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 32
                    Mileage: 90878 km
                    Time Indication: 0
                    Date: 2013.10.25
                    Time: 13:48:41
End----------(Elapsed Time: 01:17, VBatt start/end: 12.8V/12.7V)-----------
