vibrates when the turbo kicks in
Aug 6, 2009
970
cumbria
when am driving and i put my foot down when the turbo kicks in there is a vibration between 2000rpm and 2500rpm.
i have searched on here and the only thing i found that sounded like the same problem, it said it could be an engine mount.
does anybody know what the problem could be or has anybody got any ideas?
Sep 3, 2008
873
Buckie, Moray
I had this issue on mine
Its the intercooler pipe vibrating against the fuel filter housing
Go to B&Q or somewhere similar and get a piece of foam pipe insulation and attach it to the pipe with a cable tie so that that foam is round the pipe and between the pipe and the filter housing
I read about some people cable tie'n the pipe away from it but think it may cause the pipe to come off as the pipes designed to have some flex in it
Altech
Ibiza PD170
Oct 3, 2007
1,996
London
I had exactly the same problem with mine (sounded like a mechanical noise!) A bit of pipe insulation and a few cable ties around the boost pipe sorted it :)
joesmad4it
Cupra TD-aight!
Mar 11, 2008
229
Wickford - Essex
That must be what I'm hearing on mine! Any chance someone can get some pics or more detailed description of where I'm suppose to be looking as I had my head in the engine bay for an hour today and couldn't find where you mean.
Cheers :)
