I have been reading posts about cooling fan operation and i am now more confused than i was before! I have a 2004 seat leon curpra 225.
At present the small fan runs continuously when the air con is on. With the air con off my liquid display will go up to 105 0C before the small fan cuts in. The fan will only run for a minute untill the temp goes down to 100 0 C. The temp gauge in the dash never moves of 90 oC (when warmed up)
When should the larger fan cut in?
Should both fans come on together?
At what temp should is go to fast speed?
where is the sensor which controls the fans? is it the same one as the gauge in the dash?
With the air con switched on the engine never over heats my liquid gauge shows between 75-90 oC.
Thanks, any help would be great!
