Common Leon MK2 Problem Log
shnazzle
Glass-Half-Full Member
Sep 9, 2011
3,480
Northumberland
As proposed by Redemption, based on my post, the forum is a great place to look for common issues with the MK2 in order to provide our service garages with an extra little checklist.
May be handy to, perhaps post-discussion, post the issue in here with links to threads with resolutions.
Reactions: Knighto
Redemption
1,771
Hampshire
Redemption
1,771
Hampshire
ABS/ESP Light stuck on. This is a common fault across the VAG range and affects lots of models, not just the Leon. Info in the link below:-
www.seatcupra.net/forums/showthread.php?t=234463
There is also info here as well as a company that can repair the problem should Seat not be able to help or prove to be too expensive.
www.sinspeed.co.uk/blog/volkswagen-...-brake-pressure-sender-sensor-switch-failure/
I must say that I am not affiliated with them and have not used their services but the info on their site is useful.
shnazzle
Sep 9, 2011
3,480
Northumberland
Another link with good DIY info
http://www.seatcupra.net/forums/showthread.php?t=330365
tony323ci
Lovin' it
May 15, 2011
975
Nottingham
Still under warrant Mike so was done FOC some folk have quoted around £40 for the fix it's just a bit of sticky back foam a la blue peter :)
Jarre
5,365
11
Stockton-On-Tees
I don't know if this is of any help, but tomorrow SEAT are replacing the O/S Shock bearing mount under warranty, after I complained of a squeaking from the suspension.
Also tomorrow my bonnet soundproofing is being done after the dealer said it couldn't be done through warranty, I showed him the TPI number off this thread and now he is more than happy to replace it under warranty :D
Thanks seatcupra users!
