Toyosport FMIC Guide
kevinking2020
428
Herne Bay, Kent
received toyosport fmic the other day and took a few pictures and thought i'll do a guide.
Might come useful when someone gets a toyosport fmic.
Here's my fmic and guide.
Straight away got to work and started fitting it.
First off remove the Fog grills and black plastic strip.
Removed the two screws each side.
Removed the two screws that where behind the black plastic strip on each side.
Next removed the torx screw each side of the arches.
Didn't have much access to get to the guides inside the arches so had to remove wheels and then removed two screws.
Now I was able to remove the bumper.
Decided where to place the intercooler mountings and started drilling.
Looking good so far.
Removed the left headlight which made it easier to get access to the smic and started removing.
There are three srews holding the smic and are very noticeable. Be warned when removing the map sensor the bolts might snapped as mine did and where very rusty.
Starting installing the pipes for the new intercooler, started from the inlet first.
Tightened all bolts.
next started on the other side and for more access it best to remove wheel as had to cut through plastic.
Now the front is all bolted up.
Took abit time to tightened bolts as there's not much room.
Now all pipes are connected and bolted up. Here are some finish pictures.
Now putting the bumper back on was a pain in the arse had to do alot of cutting as the bumper wouldn't fit on but I'm not to bothered as in the future i want to get a better bumper.
Didn't have time to remove the old piping and pancake but will do that soon as.
Don't know much different as I can't tell because my map sensor needs bolting in as I snapped one of the bolts but will order so bolts.
turboboy111
445
Norwich
nice bay! trying to get mine to look that good. I have same style Leon and wanna get fr bumper before I do this, how much was the kit if you don't mind me asking?
ozzy123
49
Nice bay,want to do the same, got the facelift version,will I have to cut much of the bumber
SalSheikh
Under the Hood
Sep 2, 2009
2,756
Midlands, UK
kevin, good guide but there was another one or two on here. Sam posted one where he cut the bumper like you did and i think Mo Arif did one too where he didnt cut the bumper!
get it remapped and see her fly!
kevinking2020
428
Herne Bay, Kent
cheers mate. Yeah I didn't really want to cut the bumper but I just couldn't get the bumper on without cutting. It probably due to the way i've got the piping as it's sticking out.
Yeah I need to get her remapped but I'm still deciding want route to go down. I was thinking about getting k03 hybrid and then get her remapped but I might get it remapped and save up for gt3071 etc...
SalSheikh
Under the Hood
Sep 2, 2009
2,756
Midlands, UK
just depends on how much power you want from the car. if you can afford go the gt route. a hybrid will limit you on power in the end...
