Leon FR 05 fault code 17964
Reedy0
When travelling up hills or similar when a lot of power is needed, my car goes into limp mode and EML comes on. Ignition off and on and it will be fine again?!
Plugged a vag in an got fault code 17964 charge pressure - negative
Could anyone guide me as to where to start fixing this?
Also have a long drive on weekend, would it break my car anymore doing this?
Thanks! Pete
poliq
four-by-four fan
Aug 4, 2010
559
Røros, NO
I would start at the vacuum hose between N75 and the VNT mechanism. Start inspecting it from the turbo side..!
Hose was split on mine, exactly the same symptoms and fault code!
Reedy0
Any chance of a pic/points to show the whereabouts of this hose mate? Also the n75 as Ive heard that mentioned a few times and wouldnt mind inspecting
Thanks!
Bondiblu
Enthusiast
Mar 18, 2007
1,648
Cheshire
+1 and as said above a boost leak could give the same symptoms.
Reedy0
Ahh right. Wel I had it cleared on the vag and hasn't came back as of yet...
If its does I shall check all hoses going to / from the turbo
Cheers lads
