*** MK2 Leon FR TDI rear door not unlocking ***
J-DUB
100
Ipswich
As above the rear drivers side door will not unlock... will open from the inside.
Eager to get it fixed as it may fail the MOT.
Its annoying as i bought a five door to chuck **** in the back easily.
Your help is appreciated..
GS16LRHP
247
Another rear door issue.
They seem more common than I thought. I had the same problem with my car and had to replace the rear door lock module which was approximately £126 if I recall. Did it myself and wasn't too hard.
The door will open from inside since it's mechanically operated with a cable, the issue with my door not opening from outside was that the central locking unit was sending a signal to the door lock module, I could hear it clicking when I pressed the unlock button on the key fob. The problem with my lock was that there was a lever that was not moving into position when the door lock was opened, probably a faulty actuator.
