Ibiza Fuse layout
Forbez
Huge Member!
Feb 11, 2004
5,878
S.Wales
This would be quite useful for those with ibiza's and other car's which use the same fuse positions as the ibiza! (as i very rarely have my owners manual in work)
Fuse Layout
Fuse number: Amp
1. Engine / Engine Electronics 15
2. Engine / Engine Electronics 15
3. Engine Valves 10
4. Ignition Transformer 15
5. Automatic gearbox/ reverse
light / heated jets 20
6. Automatic gearbox 5
7. Injectors / Fuel pump 15
8. Lambda sensor 10
9. "S" signal * (see footer) 5
10. Control panel / Diagnostics /
Central locking alarm electronics 5
11. Horn / Heated Seats 20
12. Right hand main beam and
pilot light. 7,5
13. Left hand main beam 7,5
14. Right hand dipped beam / right
hand lamp adjuster 7,5
15. Left hand dipped beam / left
16. Right hand parking light 5
17. Left hand parking light 5
18. ABS / TCS / ESP 5
19. Fog light / Rear fog light 15
20. Brake lights 7,5
21. Hazard lights 15
22. Indicators 7,5
23. Windscreen washer and
pump / rear windscreen washer 15
24. Head lamp washer 20
25. Heated rear window 20
26. Control panel lighting /Control
panel display / Electric mirrors/
Dashboard lighting 5
27. Inside, boot lighting / Alarm
Siren 7,5
28. Lighter 10
29. Radio / CD 15
30. Heater 25
31. Number plate light 5
32. Engines central locking 30
Fuses above relay switchboard:
33. Electronic front windows 30
34. Sunroof 15
35. Electric font and / or rear
windows 20
36. Canvas Roof 20
37.Power socket in luggage
compartment 15
Fuse Box in the engine compartment on the battery:
Radiator Fan, 1st gear 30
ABS engine relay 30
ABS main relay 30
Metal fuses (These fuses should only be changed at a SEAT Official Service Centre)
Alternator 150
Onboard network 110
Radiator fan, 2nd, 3rd level 40
Engine distribution system 50
Glow plugs 50
Fuse colour code:
Beige 5amp
Brown 7.5amp
Red 10amp
Blue 15amp
Yellow 20amp
White 25amp
Green 30amp
Fuse 9 on the main strip:
The "S" signal is a system which incorporates steering wheel lock and ignition. Once the ignition is switched off and without removing the key from the ignition, this function allows you to switch on some of the electrical equipment such as the car radio, the courtesy light, etc.
This function is deactivated once the key is removed from the ignition
marc_safc
loving the turbo
May 20, 2008
273
Peterlee, Durham
my passenger side window doesnt work at all on my 2001 ibiza cupra it did a bit but then completly stopped... is the pass and drivers side on a different fuse?? it doesnt work even off the drivers door switch either
stoneyboyo
where is the relay switchboard? and wheres number 33 slot too? anyone with a picture would be great, because my windows wont budge one bit, and its really starting to annoy me! Thanks
justjoe
Can someone tell me/show me where the fuse for heater and aircon are?
Ive got some spares, and wanna see if replacing it will fix my problem :)
T_higgs89
Need more POWER!!!
Feb 2, 2009
209
Wirksworth
ok so im looking for the fuse that controls the remote central locking for my driver's door motor is it
or
Toga
Hi all,
could you tell me in what order those fuses are located in the box? I forgot to take note before removing them!!! Stupid me!:banghead:
Metal fuses
Alternator 150
Onboard network 110
Glow plugs 50
Thanks for your help.
JP
brodie1
Hi all,
Metal fuses
Alternator 150
Onboard network 110
Glow plugs 50
JP
where do you find the alternator fuse on the ibiza cupra???? can any1 help me
Loubidy
Thats all very well, but how do you tell which fuse is which? I need to check 26 but I don't know which one that it?
Shytot
141
Could you tell me which fuse would disconnect the drivers side electric front window as it is currently possessed! MKIII
