Guest, 🚨New Stock alert: Premium CUPRA valve caps now available in the store 👉 Order now from the merchandise store
gazjones said:they look good mate better than that wobbly boost gauge!!! look very good see you went for three gauges due to the problem of not being able to get a single pod pilla mount?
Why get a 30 PSI boost gauage which is about 2 Bar when your remap will be peaking at between 2.2-2.4 bar. Surely you need a 2.5 bar gauage minimun if it going to be any use.Fez boy said:Only 30 psi(Not enough)
2.2 bar maybe. 2.5 and your turbo will soon go bang !Fez boy said:The gauges are Dynamyx,Oil's are electrical and boost electrical.
I had got all 3 together so that's why I fitted them to the A pillar
If/when the car is mapped correctly then yes it should peak 2.2-2.5?
